Ryan03
Platinum Member
- Joined
- Feb 26, 2006
- Messages
- 656
- Location
- Chardon Ohio
- Tractor
- Farmtrac DTC270, Kubota G5200hydro, Honda recon 250, Suzuki King Quad 450 4x4, 2003 2500 DMax/Allison 4x4
The 6.5 td is not neccesarily a bad engine, it is just that when compared to the offerings at the time from Ford and Dodge, the 6.5 was much less powerful and had a life expectency similar to what could be found in many gas engines of the same vintage. By far what most commonly plagues these engines is the DB4 drive by wire injection pump found on the 1994 to 2000 model year engines. The F.M.U. [fuel management unit ] would often take a dump as early as 40k miles and most often by 90k., resulting in a ride on a hook to the nearest service garage for an injection pump replacement, $$$$$$. If you do buy this truck, and end up replacing the injection pump, I would strongly recomend doing what I have done with several of my fleet customers and swap on a earlier 1992 to 1993 6.5 td mechanical injection pump, stanadyne model number DB2, you will also have to obtain the gas pedal and all throttle linkages and brackets from either a salvage yard, or your local G.M dealer, but it is a direct bolt on swap, all fuel lines as well as the injectors and mounting arrangement, timing mark, etc are identical to the electronic pump. The mechanical pump is usualy good for 100 to 125k without problems, hope this helps
