Junkman
Super Member
Tire wear has as a determining factor the rubber compounds in the tire. A tire with a better stopping distance will have a softer compound and will not last as long. This is why all tire manufacturers now have tread wear letter codes on the tires. When comparing tires, you have to compare all the factors and pick a tire that is proper for your vehicle and your driving habits. I would rather have a tire that has good stopping ability and less total distance of tire life. To me, a tire that will stop the car quicker might save me from an accident. Tire pressures are also very important. When the Firestone tires that came as OEM on my wifes Ford Explorer were replace, the tread was barely worn in comparison to the mileage the truck had traveled. What did surprise me, was the soft sidewall that gave the truck its smooth ride. The Michelin tires that Ford replaced the Firestone tires with, have a firmer side wall and a softer tread compound. I have noticed that these tires are wearing much more rapidly that the OEM's that the truck came with. I also notice that the truck stops better in all different types of weather than it did with the OEM's. In wet weather with the OEM Firestone's, the truck was like trying to steer a squirrel. Now, it is much more stable.
If your truck is squirrelly to drive, check the idler arm to see if there is any play in it. That one item can and will make things very precarious if it is worn. Also, replacing it with a aftermarket part can also lead to what is know as "bump" steering. This is where the alignment is constantly changing as a result of a part being used that was not up to par and has altered the geometry of the front end parts. I suggest that you look for a shop that specializes in truck alignment and discuss the problem with them. These are the people that are the "real" experts when it comes to resolving problems. Many times a persons alignment choices are based on price, rather than quality of the work. Other times, they pay a high price and get mediocre work anyway. /forums/images/graemlins/frown.gif
