After reading several post it seeems we have an injector pump problem. Tractor cranks but won't start. Gas tank to fuel lift pump line checked. Fuel lift pump to fuel filter line checked. Fuel filter to injector pump line checked. All these lines getting fuel but when crack injector line one right above injector pump and crank engine no fuel. We also changed fuel filter when problem first happened thinking clogged fuel filter, but after new filter and bleed same thing. Also opened bleed bolt on injector pump and plenty of fuel.
Purchased tractor in june of 2006. Does anyone know if kioti was still putting injector pumps with plastic gears on dk45s in 2006?
Called kioti today and was told to talk to dealer, but had already talked to dealer and mechanic twice and they insist it is bad fuel. We have bought fuel from same place for six years now and two other tractors using same fuel and no problems. So kioti customer service says they will call dealer for me and see if we can bring in part for inspection.
If replace part, looks like intake manifold to engine will need to come off. What to watch for if taking this off? Found spec for removing injector pump from another post for ck35 and it just says to remove intake manifold.
Does anyone know best place to buy part for dk45s?
