MikeD74T
Veteran Member
Actually, it's worse than that. It is a transportation tax. Applies to railroads too.
I don't know either way, but how can a road tax apply on private property which most railroads are? MikeD74T
The IRS (and VA follows their guidelines) charges $10/gal of tank size with a minimum fine of $1,000 (you pay $1k for tank up to 100 gal in size).. BUT somehow VA will/can also go back and assess you for the tank size on your farm (assuming that is where you fueled up)..
IF the IRS makes a stop they let VA know and we piggyback on their assessment. And if VA makes a stop they IRS piggybacks on the VA assessment.. So you will end up owing at least $2,000 in penalty.
You will also owe the tax on the fuel - .40ish fed and .175 VA per gallon
Brian
I also live in the "puget sound" and have never been checked for dyed fuel though I own a tank of it and use it for the tractor. So where exactly is this crazy IRS guy and is he bothering regular people or just picking on you due to your farm and your exempt plates?
I haven't heard of that, but I have heard of some sort of "test strip" that can be placed in the exhaust. Not sure how it works...For years they dipped tanks and sent the sample out to be tested, supposedly they now have a set of binocular type glasses that can look at the tailpipe vapors and see if they are emitting something? Anyone heard of this?
They filter it BEFORE it goes into the tank.i don't see how filtering the dye would help when they check your tanks,not your filter or lines.
