Dmace said:So you are saying, I could put a 21 hp gas engine in my tractor with the same gearing and same hydraulics with no difference in work produced?
I don't think so!
Yes HP is HP, it's just a number. The difference is how the HP is made. Which is stronger ?, something hitting a 33,000lb object up 1ft over a period of 1 min or something pushing 33,000lb all the way up to 1ft in the same 1 min.
Here is a link about where the formula came from.
What is Horsepower?
You don't think so? If you get a gasoline fueled spark combustion engine that makes the same HP at the same rpms as the current diesel engine, it will do the same amount of work. (Assuming that you match the weights of the engines)
I don't know how old you are, but in the 50's, 60's and 70's you could buy tractors of the same model with gas or diesel engines. Heck, you used to be able to get LP powered, gas and diesel all in the same exact model of tractor.
For example, 1963 Ford 4000 tractor could be bought with a 172 CID Gas engine or a 172 CID Diesel engine. Both 4 cyl - 3.60 stroke - 3.90 bore. Same basic block, head, crank, rods etc. Changes were made to accomodate the diesel with combustion chambers, compression ratios etc. But they were the same basic engine. They both were governed to the same RPM's even.
Here's the big question; Which one was able to produce more work?
I assume from your previous statements, that your answer would be the diesel, right? If so, WRONG! The gas engine made more HP and more torque across the entire RPM range. I can dig up a Ford dyno curve of both engines, but the ratings are 56.3 hp at 2200 rpm for the diesel and 62.6 hp at 2200 rpm for the gas. That basic difference was the same at all rpms.
The diesel was (and is) more efficient due to the increased compression ratio. Gas is 7.50:1 and the Diesel is 16.8:1.
jb
