JC-jetro
Elite Member
which end did u put the seal on from having hard time geting over the piston.
I just sent you a pm explaining it again. The outer lip of the seal should face the cyliner head that you removed. The opposite will not work. Imagine as the pressure increased due to flow of oil that expands the outer edge of seal lip toward inside of the lift cylinder so you will not have any blow by back to the differential, as I explained before it is a tight fit. I would not use any direct heat. I'm thinking you might put the seal out in the sun for a 15 minutes to soften it just a bit. I have heard people put the seal in the warm water (not boiling) and that expands it some. the hyd fluid at time can get pretty warm. Put the seal with the lip facing the the front of the tractor, make sure not to put the piston in reveres. The front of the piston is flat but the back side has a depression that pushes the fat rod there. keep the seal lubed and squared to the piston and slowly push it in. if you have a helper may be two people can push it more evenly on four sides. Really it is not very difficult. let me know how it goes.
JC,
ps. look at #12 post and 3rd and 4th picture. that shows the orientation pretty clearly.
