BWBrown
Bronze Member
- Joined
- Oct 28, 2007
- Messages
- 84
- Tractor
- Ford 1700, IH 2500A
To respond to the question above... yes, it is common to use glow plugs to start, especially in colder (sub 40 degree) weather.
I have no answer as to the life expectancy of the injectors, but I suspect I have one that is due for retirement. I don't know about cleaning. I do know that some of my diesel truck friends speak of having injectors reconditioned. I may try to look into that.
I also echo the use of Power Service, or any other additive, they aid diesel life expectancy for many reasons.
Push starting might be interesting and challenging. I shy away from starter fluid (unless really in a bind), though I see big truck drivers using it regularly. An old diesel mechanic friend told me about putting a rag (wet with gasoline and wrung out) over the air intake to make diesel starting easier. I have done it twice over the years, worked both times. HE said it would not "wash off the cylinder walls like ether does."
The 1700 is an older design, mechanical injector pump machine. Sometimes takes awhile to get going, but once running will always work for you. A well warmed up engine will restart easily.
Bob
Bob
