Docsknotinn
Veteran Member
Richard, I just do not understand why you try to candy coat the facts for Ford. You used the same argument about it not being a Ford problem on the Firestone issue. Ford is ultimately responsible. Period. It is most certainly a Ford issue as those parts were made to their specs. If you believe those numbers Richard I am happy for you but to be perfectly honest with you I think that a 3% failure rate is laughable. I personally know well over a dozen guys that have had Ford injector failures and that does not count any one on the net or their extended family. One of my neighbors his brother and dad all had failures. Yes Gm has had their failures as well. Mechanical things fail and it is a pain in the rear, Especially when your hiney might be hangin out after the 100k mark. Gm at this point has a failure rate VASTLY lower than Ford. If it catches up you can be sure it will be front page news just like it is for Ford here now. I am not knocking Ford. I have owned more Ford trucks than all the others combined. Living in greater Detroit a large percentage of my income can be directly traced back to Ford, Gm and Chrysler. When any of the companys mentioned get in a pinch it is not good for me. I can sum it up like this Richard. I bet you a bottle of Bourbon and a steak dinner that the failure rate in question is higher than 3%. I'll bet you a case of your favorite poison that neither you or I will ever know the real numbers.
