I don't understand why you don't understand.
When you pull the door down, you are pulling against the spring tension that is holding the door up by the cables. When you pull, the cables pull the drums, turning the shaft.
When the opener closes the door, it turns the shaft and the drums. The cables spool out letting the weight of the door (gravity) keep the cables tight as the door closes.
"I don't understand why you don't understand", Thanks for the humor, nice to read something funny after welding all day.
So if I'm reading your LiftMaster 8500 lesson right, when I pull the door down, I'm pulling against the spring, turning the shaft and winding up the spring as the door comes down, the cable on the drum that's on the shaft, free spools out, because it's hooked to the bottom of the door, staying tight by the weight of the door (gravity).
Now lets see if I understand this so far, according to Einstein's Theory of Relativity, this means when the door is all the way up, there is very little tension on springs, I cut the cables on both sides of the door, the springs will finish unwinding a little, then there's nothing holding my 12X12 foot door up, and the door come down fast, staving it all to pieces, (gravity). I'm still not sure I understand this, to prove it to me, someone should buy 12 foot door and with camera rolling, cut the cables, put the video on YouTube, then I'll be able to understand how my overhead door works, thanks for your understanding
