Re: Hinged Box Blade to pin or not to pin? How\'d Udoit
Steve,
I also took some pics of the latest project. It is using both the kubota with the box as well as an old Ford with a backhoe.
If you look at the front of the tractor, there is a "road" down the hill side. I had dug the hill out and there was a 3 1/2 foot ledge. I scooped out a step and then went up with the Kub and box then went down - 2 times in each direction for the width. The soil there is sod/sand/gravel in layers. You can see the nice job the gannon did.
In this pic, you can see the work area leading to where I am dumping spoils from the hill and the hole. I fill the bucket, back up and drag out the box. The box is set up low on the left, to flatten out the hill side so the hoe isn't pulled into the hole! It works pretty good, on average when spreading the spoils, the roadbed in the drag area will be lowered about 1'.
Last one is just a pic of the Ford doing it's thing. The area where it is sitting was full of dirt from the hole from the shown pile 20-30' past the front of the tractor. The Kubota and box do a nice job moving it.
Ok, the last last pic! Shows the bottom of the hole and the side wall. THat side is full of gravel on top, shale in the middle and sandstone on the bottom.
jb
Steve,
jb
