ctgoldwing
Platinum Member
I split about 2 rick of wood today on my log splitter. Logs were all huge and pump was in low volume/high pressure mode most of the time. Cylinder was very warm to touch. Not so hot you could not hold your hand to it, but very warm. I would guess about 140 degrees. Is this to hot? I have a 10 gallon tank and have never felt it this warm before. Usually, I split when it is much cooler outside. It was near 80 degrees today.
The touch method can be deceiving:
"A safe temperature for hot water is 110ー F, which exposure to results in third degree burns in approximately ten hours.3 Even though this is a 'relatively-safe' temperature, exposure to water set at 110ー F is painful; the human pain threshold is around 106-108ー F."
" An approximate one-second exposure to 160ー F water will result in third degree burns.1 Where the water is 130ー F, an approximate half-minute exposure will result in third degree burns"
