oldnslo
Super Member
"Heat" is a very relative term!! Cold too!!
"Heat" is a strong term, and usually not a god word to use for describing increased temperature, because it is RELATIVE....
Actually, straight physically, there is nothing like cold, according to William Thomson, 1st baron kelvin, that discovered the absolut temperature scale.
Thomson found out that at a certain lowest material temperture, there is a theoretical absence of all thermal energy. No molecular activity. That temperature is about minus 273 C, or minus 460F...He gave that lowest temperature Zero, on his own scale called KELVIN, which is also the official international system scale for temperature......plus 273K=0C=32F....
Hammering metal or stretching rubberbands etc, is molecular stress or molecular movement, that causes friction. So is pouring fluid out of a bottle. And from friction we get "heat", or better, INCREASED TEMPERATURE.
So by forcing material to deform, pour, flow, change volume, etc, we transfer some work energy into increased temperature ("heat") in that piece of material....That happens around everything that moves....
Pressureize oil in a hose, wont create any "heat", maybe some 0.1 or 0.01 of a degree temperature raise. But if we force that oil to move, there will be friction, and that will be a "heat"-factor of importance....the more we restrict flow, the higher pressure is needed to maintain flow, and the higher temperature increase we get.....Broken piston seal, leaking relief valve, worned out pump, clogged return filter, elbow fittings, undersized hoses etc etc.
+ 1 on this. A good functioning cylinders does NOT create heat when doing work. In almost all case a componet doing work is not creating heat. The Inefficiency of that component is what creates the heat. I.e. pump slippage, valve pressure drop etc.
Largest heat generator on most log splitters is the pump itself, second is the valves and plumbing.
A good hi-lo gear pump is probably around 85% effecient and when the low section unloads this gets worse since a portion of the same fluid is being recirculated in the pump itself.
Roy
