oldnslo
Super Member
Ken,
years ago I was taught you should be able to hold a count of five on any reservoir or component to be safe (right around 150 deg)...anything hotter should be questioned...Seals and hoses start being affected around 185+
Industrial reservoirs rarely get to 130 degrees, mobile equipment reservoirs will regularly get above 150 degrees. I have been told that 220 degrees is not uncommon anymore on mobile equipment. Ag equipment I suspect runs in the same range since for "efficency" they are running engines hotter.
Side note: Engines run above 180 degrees and their seals last.
Roy
