So I went in to Tractor Supply and told them I wanted to buy one of those "leveler thingamajigs" but they just looked at me like I was nuts!
Any additional specifics or perhaps a pic would be appreciated!
Like handtools said - I think the leveler thingamajig = Land Plane Grading Scraper(LPGS). The LPGS will fill and level out the washout gully - start at the bottom of the driveway and pull material up and out as you move up the driveway. Your material is still there - its at the bottom of the hill or in the driveway ditches.
The LPGS is NOT the tool to do any type of work on the driveway ditches nor is it the tool to create a crown in the driveway. A heavy duty rear blade will "do" the ditches and will "create" crown on the driveway.
People become upset when they go up/down their driveway many, many, many times with their new LPGS and it DOES NOT create a crown. Simply not the tool for that.
LPGS is a VERY EASY tool to learn to use and use well. Rear blade has a loooong learning curve - but is the main tool for driveway repair and maintenance. The rear blade can actually create problems on gravel driveways because of the short wheelbase of the tractor and the close attachment of the rear blade.
Its up to jymbee - buy a LPGS and smooth out the driveway. Buy a heavy duty rear blade - start learning how to use it - smooth out the driveway - reestablish the crown - clean out the driveway ditches. Along with the rear blade - I would recommend a hydraulic top link. It is of great help in learning how to use a rear blade.
Not sure exactly what you're referring to re. "screenings"?
A rear blade is the PROPER tool to maintain that driveway!
Everything Attachments is selling what they call their Deluxe Value Blade which could be just perfect for the OP's driveway.
They make the blade in 5', 6' and 7' lengths.
It is rated for up to 50HP, but looking at their videos on the blade, it looks plenty beefy enough for a 52HP Massey.
I think their 7' Deluxe Value Blade would be the most cost effective solution, at $856 incl. shipping.
They have two excellent videos on their website for the "Deluxe Value Scrape Blade".
I ordered the 6' version just 2 weeks ago, but have not received it yet.
Screenings come from the rock processing guys and are available (in our area) from any supplier/hauler. It is the sand-like grade of (granite) rock that collects under the classifier screens. It is quite fine and packs to a nearly solid surface.
paul
Is this the material your describing? I could use a semi load of that stuff if I thought it would work better than the gravel we have now. Gravel around here has a lot of rather fine silt which comes to the surface over time and creates lots of dust. Also washes out too easily.
Stone Dust | #1 | NJ, NY, NYC, PA
