</font><font color="blue" class="small">( C'mon now Chris. You know good and well that I'm not picking on a gear transmission )</font>
I know.. I forgot to add the smiley /forums/images/graemlins/blush.gif sorry.
</font><font color="blue" class="small">( one arrogant guy. I can give you tons and tons of instances where someone has been stuck by an unscrupulous dealer on a repair of a standard transmission. I've had several dozen apart. I assure you that clutch discs, pressure plates, throw out bearings, synchronizers, incorrectly cast gears, thrust bearings etc. etc. can and do wear out. That's not to mention the sand from cheap castings that I've found in some of the cheap imports )</font>
I a;so agree.. a shelled out gear tranny is still going to be an expensive rebuild... I have a feeling it will be slightly less expensive than a hydro. I also get the feeling after looking at a parts manual.. that if I had 2 tractors with bad trannies.. and one was a hydro.. I'd send the hydro to the dealer... I feel confident in pulling the gear trans apart way more than I would trust myself inthe hydro tranny. Similarly.. many of our local tractor repair shpos usually refer you to the OE dealer for hydro trans repairs... though i do know that one local guy will work on dual power setups and the like.. etc..
Soundguy
