JC-jetro
Elite Member
The inner high pressure seal blew out and the outer shaft seal followed because it is not designed for high pressure. It's function is more to keep engine oil out of the pump than to hold hydraulic pressure inside. With both seals blown, the engine was slowly filling up with hydraulic fluid.
The service manager told me that the first one of these they did, they just replaced the obvious outer seal. He said when they installed it back into the tractor, it instantly failed again and they learned that you should always replace both seals for a reliable fix.
Cool , On mine the input shaft seal blew out just due to age and drying out, but I replaces the inner seals as well. I remember we had a discussion many months ago that at " lower pressure setting" around 2000 PSI and I'm able to do all my lifting tasks and whether it was advisable to up it to factory spec and the answer was " not really". The flip side of it is that guys always want to shim things up or fiddle with pressure setting to get more raw power... . I reckon if I had loader I'd be looking to do the same.
Glad you got her working and as usual leaving behind good information for the folks here when needed.
JC,
Ps. For me, I would not lose a raw opportunity like that to get close and personal with the pump by trying to overhaul it myself.
