Please forgive me because I'm not up on hydraulic terminology. This is pretty new to me.
I raised the outrigger, moving the piston from the rod end of the cylinder to the base end. I tied the outrigger to the tractor so it would not fall down. I disconected the hose from the base end of the cylinder at the valve and placed the hose in a catch bucket. I started the pump and moved the valve to apply fluid to the rod end of the cylinder. When I did this, fluid came out of the disconnected hose going to the base end of the cylinder. I returned the lever to neutral and repeated several times. I bled off a couple of pints, way more than could have been in the cylinder and hose several times over.
Same on both sides.
I still don't have a t or a gage. They are on the list.
Same on both sides.
