HI: Everyone, after reading your post, it appear I am having the same problem. KEEPING MY JOHN DEER RUNNING. I have an older John Deer L120 automatic. For the past several months I have not been able to keep it running after it starts. I have cut grass two of three times with it this pass summer. But each time I get it out to use, I have the same problem getting it to star and keep running. So far I have taken apart the CARB, let the whole CARB, Float bowl soap in gas for three to four days. I think my problem is with the solenoid switch that housed(connected) at he bottom of the CARB. I am not sure if it is working of if the wire connection that connects to it has a good connection. The wire ends that fits in the end piece of the wire connection that slaps into the solenoid came loose, and I am not sure I have put it back together wit a good connection fit. T he other end of the solenoid wire connection goes to the motor, and I cannot see where it connect to the motor, because it goes between and behind the front of the motor attached parts. I cannot not see if the end of the solenoid connection wire has come loose. Two question 1. What do this solenoid piece on the bottom of the Carb do, its function???? 2. IF the solenoid is not working, or have a bad connection on either end of the solenoid connection wire, will this cause my John Deer to not keep running. So far each time I start it, it appear to only run from the amount of gas I manually pour down in the CARB and cuts off. This old John Deer runs GOOD when it is running. Can anyone tell me how to test/check The short solenoid switch to confirm that it is good, and to test/check to see if I may have a bad/loose solenoid wire connector, which may be stopping the solenoid from doing its job. How can I test both?????? JOHN DEER L-120--20 HP --BRIG. & Stratton--48 inch cut...S/n>>4067770128B1>>>>>30610Yg00392>>>>GXL120A067917
