kennyd
Advertiser
OK, I didn't check what I have left over, I always look at that as a job well done when you have stuff left over.
Well, go do it!:laughing:
So you had the same problem?
Yes, as well as a few others over the years. I could not get any usable pressure out of the new valve I added: Rear Remotes on a JD4110 - TractorByNet.com
It stems from the instructions NOT detailing this.
I think tomorrow I'am going to disconnect the return quick connect and start the tractor and engage the splitter valve, QUICKLY. If it moves then that tells me the 2 lines were, are, charged and working against each other, thats why its not working. Sound logical???
You can try...but it seems easier to see you you have that screw leftover
I even pressed the quick connect while it was running to make sure It was pumping and it was, MESS.
You will get some fluid from it-but it just won't be under any usable pressure. You need to be REAL careful doing things like that...The fluid can be under 2500lbs of pressure (if you have the screw installed) and can be injected into the skin. Gangrene and amputation follows soon thereafter.
I always have trouble retriving the old messages, am I doing it wrong or will I ever figure it out.
Make sure you check the "remember me" button when you log in, and the click the "since my last visit" anything you replied to will have a check-mark.
