KYErik
Platinum Member
- Joined
- Dec 2, 2005
- Messages
- 893
- Location
- South central IL
- Tractor
- 1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I would cut a block of wood to hold the clutch pedal down and then start it in neutral and let everything warm up and run awhile. Vibrations from the engine may help work it loose over time. Leave the block of wood on the pedal all the time.
Adding vinegar or brake cleaner is worth a try- it couldn't be any worse than water sitting in there for months. Put it in high gear and have another tractor just tug/push on you a little- just a few inches back and forth.
