3Ts
Elite Member
Make sure those filters you replaced are seated properly.
This is good advise and completely true, however in this case the OP stated the fluid is foaming.Not sure if you mentioned it but my B7800 gives different transmission level readings. One when it's cold and the other after it's been run a while and warms up. When I check it cold and before it starts, no fluid shows on the dipstick. When I warm it up and check it, I get a reading. Had I filled it to a "full" reading on the dipstick when cold it would likely be very overfilled when warm and would likely blow oil out the vent tube. I have seen this happen..
I still want to rule out fluid level as that has been the only reason I have seen Kubotas blow oil out of the vent tube. Just my free advice.
My thoughts from afar, what I would do with the same symptoms, after replacing filters with OEM parts. You have a 10 year old machine, the following is cheap and relatively easy maintenance in the scheme of things, and will help to fix, or rule out some bits. The most likely cause of aeration is the suction elbow, remove and physically inspect, squish/feel/replace, if at all hard or any sign of deterioration. However there are a couple of other orings in the circuit, and are worth doing while you are there. Remove suction line and oil filter housing, replace oring to tank and oring to line. So order the parts, fit them, and see if any improvement. The drained oil can be put back into tractor, run it through a sheet if any debris has dropped in it. YMMV.
Did you also pull the suction pipe and check the oring? Do you have an IR thermometer? If so put it on your pump when you start engine and see if there is excessive temperature rise in either pump.
Whilst checking your nipples is always a good thing, the nipple is simply "inside" the hydraulic circuit and if oil bypassed down the minute cavities in the threads, that tiny bit of oil is just bypassing the filter. If air was to bypass, then there is no oil there, so you have a major problem as there is no oil in the tank getting to the nipple. If the nipple was cross threaded in the filter housing, it may stop the filter from screwing on far enough to allow the gasket to properly seal.
Thanks, when I get back I am going to drain the fluid and replace both o-rings, check nipples while I have it torn down. I did notice yesterday that after the oil and air stopped coming out of the vent I heard a loud bubble sound inside the tank and the oil level dropped when the air escaped the fluid it has blown enough oil out now that the level does not even touch the stick after I let it sit for awhile.
