John the oil coming from the vent was from the pump sucking air. mine was a bad seal in the suction of the pump. a lot of the time the elbow on the suction side of the pump is the cause it will have a hole in it.
Did they ever get the power steering problem fixed? When last you posted, you said that the Kubota tech had been out 5 or 6 times and that replacing the pump fixed the foaming but not the hard steering.
What bothers me when I hear about things like this is that it shouldn't really be so difficult. I can't help wondering if sloppy diagnostic work like this is evidence of the new wave of technical ignorance - or just lack of caring.
This should be a one day job for the factory tech...a couple at most. It's been what? maybe 4 months??
When something this simple takes so long, I lose my patience. I just hate it when the conclusion has to be between ignorance or deliberate inaction.
If they haven't provided you with some sort of loaner or compensation, I'd be renting a tractor and billing them for it.
If you still want to get involved in the repair - something I encourage you to do - ask the Kubota tech to go through the results of the readouts on his hydraulic flowmeter next time he comes out. That is the basic diagnostic tool for hydraulic work. Sort of like a VOM is to electrical system. His will be the kind of flowmeter with adapters for all the places it can be inserted inline, set to a proper flow rate range for system being measured, and with pressure and temperature readouts as well.
Any tech guy that shows up the 2nd time to look at a hydraulic problem without his flowmeter either doesn't know his trade or is deliberately making the diagnosis a guessing game rather than a job to be done. Either way, he is avoiding diagnosing the problem.
I'll admit that The foaming is a different problem - although a flowmeter can help there too. In fact, Nothing else is as good as a diagnostic aid as a flowmeter.. Foaming usually means air is usually being sucked into the suction side somewhere and is often fluid temperature related. I've heard it is theoretically possible to suck air into a localized low pressure area in a high flow rate pressurized line - but I've never seen it.
Good Luck
rScotty
BTW, I apologise if I came on a bit strong, but I've done some fluidic engineering consulting and don't understand why this should be so hard. It frustrates me and I'm not even there....I can't imagine how the poor owners must feel.
