6sunset6
Veteran Member
- Joined
- May 6, 2007
- Messages
- 1,056
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
Thinking a little more about your valve selection. I think the two valve block is fine, except that you might want a detent pressure release on the retract motion. This allows hand on the valve holding for extend or split and then pushing or pulling the handle for retract and letting go. Retract will stop by itself when it hits the end of the stroke. IF you are doing logs shorter than the cylinder stroke you can clamp a sled stop on the beam and the retract will stop there. I went with the full auto valve and it is not worth it. Half the time it does not go into auto retract so I have to hold my hand on the valve anyway. If the machine runs fast enough you cannot move away anyway.
You might want to consider a third spool if you ever want to add a wedge lifter.
With respect to speed control use 1/4 hoses for the lifter. With a 22gpm pump you might have to restrict further, Even with 16gpm I feather the valve quite a bit. Restrictor fittings are available . They have a very small hole in them. Or a needle valve in one of the lines. get one with out a check , then it works in both directions.
You should look for a cylinder with the largest diameter rod available. Mine is a 4.5" diameter with a 2.5" diameter rod. Not so much for the retract speed ,although that is a factor, but for the bending load on the ram. A 5" cylinder with a 40" stroke will more than likely flex the beam, try to lift the sled, and generally stress the whole system. Mine does that occasionally and I am learning how to avoid it. Mostly watch the knots.
