LD1
Epic Contributor
Maybe IO and TW only set theirs up at 2000 sys press? If so 11hp should run it.
Im guessing the reason they run the bigger motor on the TW6 is so they can run higher pressure on the LP side and HP side. The TW6 is 2 tons more than the tw5 with the same cyl so sys press must be higher. If you have the lp shift point set at 750psi and max press at 3000 your going to need all of 15 and likely 16 hp. The TW6 is 2 seconds faster on the cycle time than the TW5. The 688cc Honda is about 20Hp peak. The way I figure it, ignoring the calculations, that's about what you need if your going to max out the pump on LP and HP and have a bit of fudge factor built in.
The TW-5 is (11hp, 22gpm) listed @ 25 tons with a 5" cylinder. To get 25 tons out of that cylinder requires 2500psi+.
I dont know how they are doing it either. But they are. At only 2500psi, spec calls for just a tad over 11hp with 85% eff.
I wonder if this is one of them cases of differing measurments for HP. (gross, net, sae, din, etc) (you mention the class action suit).
Or maybe HP is just different up there in Canada:laughing:
