mikehaugen
Elite Member
That one is going to be a little tougher to answer. It is all going to depend on how it is designed. IE: you can use a long stroke and small bore cylinder or a short stroke large bore cylinder or anything inbetween.
What you need to do is sketch out some rough dimensions as to how big the log lift is going to be (from pivot to ground), and where you plan on attaching the cylinder to it at. Then you can get a rough Idea of what you need length wise (retracted and extended measurment). This will get you the stroke length you need. And then just depending on where its mounted (leverage), and the angle it is mounted on, and we can figure out the force needed. (bore diameter).
But it is going to me a MUCH smaller cylinder than the splitting ram. So unless you are wanting to build a firewood catapult, you may need to incorporate an adjustable flow valve in that circuit.
so what is a good figure for weight of a log... say you were wanting to split a 36" log 24" long?
