747driver
Great to see Aye working and herding the goats in her young life. Seems as though she is a natural !
I would not be straight wiring the furnace. You might damage the furnace and burn the house down. I would call in a tech to look at the thermostat hook up. something is wrong. The furnace needs to cycle on/off to keep it from damaging the heat exchanger when heating.When I built this house I planned three heat systems. We have 3,000 feet of pex tubing in the slab and a Rheem Combi Boiler. We have the MR Cool Minisplits. And we have a Jotul Rangeley wood stove. I installed the pex tubing in three zones. Basicly zone 1 is the 3 bedroom far side of the house. it's actually Lauren's room, lauren's office and Jefanna's office. Zone 2 is the main room (living room, kitchen, dining area). Zone 3 is the master bedroom side of the house. Mechanical room is located in the master bedroom side of the house. And Lauren's room is on the opposite corner of the house. Even with the 9k btu mini split she feels cold. Her door stays shut all the time, because she has two rabbits in there and the condenser is mounted about 9feet up the wall (room has 13.5 foot ceilings. the other two rooms over there (the two offices) have 8 foot ceilings and are toasty warm with the mini splits.
I finally gave in and tried to fire up the CH system of the boiler. I only have the zone 1 connected to the system.
My first issue was I bought a fancy smart thermostat with wireless remote sensor....I could never figure out how to properly wire it to the boiler. so I abandoned that and got a dumb thermostat that looks like an old style dial type. I still could never get the boiler to fire for CH. DHW has worked fine for us since around April. I did troubleshooting on it checking and rechecking the way I had it wired in. The concept is simple the thermostat has two wires that connect to the T-T block on the circuit board. 4.6 volts thru that block. When the tempiurature drops below your setting the circuit is connected, and the system is supposed to start heating. I turned it all the way up and nothing ever happened. So finally I got frustrated and last night around 10 I disconnected the thermostat and jumped the T-T heat input block and it fired up immediately. I left it jumped and ran it all night just to see how long it took the floor to warm up. Woke up this morning and it was 79 degrees in Lauren's room. I turned it off at 7:30 and her office was 81 degrees. So I know it works , I just need to figure out how to regulate it properly so the floor stays around 70 and if they need to they can augment with the mini splits over there. Right now the house feels icky hot. my work area in the main room is 77 degrees......those 4 lines in zone 1 cross thru the main room so it has heated the slab up in some spots in here as well.....much of the slab area in main room was already warm from me running wood stove all day yesterday. I am definitely not putting a fire in the stove this morning. I guess this is success. I just need to learn to control it.
