rbargeron
Elite Member
N80 said:..........Also, I guess there are two issue to consider. One is bearings, which some people have had to replace, but the other is just the seals. I'm not sure how the mechanics actually affect the seals.
First, to Ob1's point, "double shear" simply refers to the way the part is loaded - not how heavily it is loaded. Double-shear means applying a shear load in one direction at the two ends and in the opposite direction in the middle. The bending moment is balanced in the part. Single shear cantilevered support produces shear stress in the part but the bending moment is resisted by the support - in this case the bearings.
Second, to N80, If the design puts too much load on the bearings they wear and become loose. The flex limit of the seals can be exceeded and they let water in (or oil out). One thing leads to the other. The early A seal tolerated very little wear in the bearing before it leaked. So problems were common before very many hours of use.
And third, to BarryH, no experience fixing a center pivot leak - but I agree it looks straight forward. Can you tell where the leak is (front or back of axle?) I'd be surprised if just tightening the adjuster bolt would affect an oil leak. If the seals are intact, UDT is fine - heavier oil won't leak less, it just takes longer to drain down below whatever is leaking. Cheerful refunds to all if info is bogus. Dick B
