Kernopelli
Veteran Member
- Joined
- Oct 16, 2006
- Messages
- 2,207
- Location
- Carterville, Illinois
- Tractor
- Mitsubishi MTE2000D, Dig It 258 Mini Ex, Deere Z930A ZTR
I thought I would update this . I decided rather then taking a chance of getting the wrong bolts from an online place that gives no description on bolt specs I would go through my bolt stash .
I found what seems to be the perfect solution . Eight grade 8 , 5/16ths bolts that the threads are were a 1/4 inch to long , shoulder length is perfect , I cut them off using a die grinder chased the threads & they actually fit more snug in the carrier and ring gear then the originals . The hex heads fit perfectlly to keep the bolt from turning & i installed nyloc nuts with no lock washers . I'll get some pics before I drop the unit back in & start putting it back together .
It looks much stronger now then if I would have used the same bolts that were in it before, plus I still haven't spent a dime in the repair . I hope to have it back together & in operation in the next few days if all goes well
Thanks again for the input to all , but a special thanks go's to Darryll, I now have an allmost a complete parts manual printed out that is at least close enough I should be able to do any repairs on it from now on . :thumbsup:
BTW Al/Ampa , I have no idea how my TA 250 compares to yours, but I beleive its quite a bit bigger in size so I doubt its very similiar to the inner workings as yours .
Sounds good! I really think using appropriate bolts that you have is a fine alternative. I use nyloc nuts quite a bit but the ones I get at the local farm supply are only grade 2. I would make sure that the ones you use are grade 5 or even better, grade 8 if you can find them ( I've seen them online but can't find them locally). You've gotten this far.....I would make sure the nuts are up to snuff with the bolts. I want to see those pics of this rig running!
