just had to change a converter on one of my 2010 hino trucks(4k)some of these trucks have had 3 sets of injectors before they even hit 200k. it seems that when they changed the diesel back in 2009 (sulfer) that the new mix of fuel plugs injectors causing the converter to run very hot Hino has extended there injector wrnty from 250k to 300k for this reason it seems that the new emis sytems starting in 2011 where you have another small tank that you have to fill every 6 to 7k miles isn't having that problem but has a ton of new problems you just cant win as far as trucks go I wont be buying anything newer than a 07 for as long as I can get away with it and as far as tractors go if it has emis I would stay away also im sure in time they will get these things figured out but until then I cant afford to be there test dummy
You can that CA for all of this mess. CARB and then later the EPA kept changing the rules and even committed fraud with the science that set the standards. Over estimated the emissions by 400% and made up the number of lives that these emissions would save. Once in place though, there is no going back.
If you don't believe me, search for CARB and diesel fraud the person who committed the fraud is Hien T. Tran.
