BG- One thing I didn't see anyone mention- so I'll do it now-
Check the oil in the fuel injector. You will most likely want to add some. The 1700 has a fuel injector that you have to manually put oil into. I don't have the pic here- but you add just a little to keep the internal parts lubed.
It's all in the manual. Check up the lube information in the manual.
By the way- I just spent two days changing the water pump on mine.
Water pump on a 1700 is P/N A-SBA145016071
Got mine on e-bay here:
Compact Ford Tractor Water Pump 1500 1700 1900 - eBay (item 320511408146 end time May-02-10 09:32:48 PDT)
it came the next day.
Just an FYI- Other good parts listings can be found here:
http://www.dmtractorparts.com/aicat/aiTractors/fordNewHolland/cooling.pdf
I'm still waiting for the hoses to arrive mail order. It took me a little bit to figure out how to change the water pump- the bearing went bad- but I figured it out and it's relativeoly easy to do. Pump cost me $88 plus $11 shipping on e-bay.
