Woodbeef
Veteran Member
Me thinks you need to do some investigating yourself at your nearest Deere dealer,seeing as Deere & Company will not even tell you the truth!! Like I told you above just check the ID plates for info. Boy did they ever give you a load of totally useless info!! Deere has not made let alone assembled any utility tractors outside of assembling the 5000 series in the US since the early 80s with the 40 series. As a matter of fact if you check the Deere website it will tell you about the tractors that are made where in the press releases about each series. You'll also see that they moved the rest of the US engine production that was not already there down to Mexico except for the ones used in the US built series. The main parts for the existing 7020s including cabs,rear ends,trannies and engines have came from Europe since the beginig of the series,and now the whole range of smaller 7020s are moving totally to Mannheim to be built along sidce the full frame large 5020s ,6015s and 6020s. The black painted engines in the 5000/10/20 have always came from Mexico as does the whole 5005 series. The engines in all of the Deere utilies since the 50 series on which have always came from Mannheim have came from France.
