It is true large facilities have EDGs (emergency diesel generators) with large fuel storage tanks, but I would also expect the fuel is tested for impurities (particulate, algae, water, etc) and filtered on a regular PM basis.
I would assume that it is .... considering the amount of investment large quantities of fuel represent ....
to do otherwise would be fiscally irresponsible for one thing ....
At least that is what is done where I work.
Just out of curiosity, where do you work - and what do you do ?
If the fuel fails the test requirements and can not be corrected with filtration and/or treatment then it is pumped out. I have seen several thousand gallons discarded at a time.
So ..... what do they do with it ?
Probably a safe bet that it ain't going down the drain .....
So the point is that while the fuel for large EGDs is not "new" it is monitored and cared for quite carefully. I suspect this level of care is outside of what is practical for a homeowner to perform.
Likely true - but then there is level of care required to prevent any problem to a near absolute 100% certainty (given the consequences that might accrue if that level of care were not exercised: loss of life, etc.)
And then there's the level of care required to be reasonably sure that you aren't allowing a problem to develop .....
The average homeowner isn't generally in the position where his care (or lack thereof) of diesel fuel is a matter of life and death, or a serious disruption to the public at large.
If I can't mow my grass tomorrow morning because I need to go to the dealer and pick up a new fuel filter, it don't have quite the same consequence
as the Intensive Care Unit being without backup power and unable to keep someone's ventilator running ..... it just ain't quite the same deal .....
The issues surrounding properly caring for long-term fuel storage aren't terribly complicated, the data is known (or knowable), there are commercial products and solutions available, and it **** sure doesn't require holding an advanced degree or a Chief Engineer's License:
1. Keep a clean tank (
uhh .... you might wanna to drain and clean it out occasionally, on a periodic basis, when it gets low) ....
2. Use a biocide .... (
to treat your fuel and prevent the plants and bugs from growing .....)
3. Filter your fuel before you put it in your equipment ..... (
..... could possibly include the use of a water separator on your pump)
If ya feel the need for "periodic filtering on a regular PM basis", next time you are out in the shop working on something, just stick your fuel nozzle into the filler opening on your tank and let 'er run for 10 or 15 minutes .....
do that a time or two per week, and after a month you'd probably have the cleanest fuel in the county ..... Of course, this assumes one is bright enough to have a filter on their dispensing equipment.
If ya have a hand pump, then incorporate pumping 20 or 30 gallons (split between each arm) thru the filter and back into the tank, into your daily workout .... I'm sure it would be really great for
"firming and tightening" ......
No need to
unnecessarily complicate the simple ....
