DEWFPO
Veteran Member
- Joined
- Jun 2, 2007
- Messages
- 1,100
- Location
- "Up High in the Rockies"
- Tractor
- 2009 Bobcat Toolcat 5600 D
ATF is basically 5w or 10w oil with some anti-foaming agents added, maybe another "magic" chemical or two for whatever purpose. Since this ATF is unopened it hasn't been exposed to air or any other contaminants and it's roughly 15 years old. Now then, how many vehicles do you think are out there older than 15 years that are running the same ATF they came out of the factory with ? I'd be willing to wager there are quite a few. My 1993 Nissan truck has the original power steering fluid (pretty much the same as ATF) and has 236,000 miles on it with no problems with the system, no leaks at all, even. I use my power steering as an example because my trans is a manual. There shouldn't be a thing wrong with that ATF - use it.
X2, and the ATF in those trannies have been exposed to heat, cold, moisture and wear and tear.
Just give the cans a good shake before pouring out.
DEWFPO
