/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 15,059
FWIW......ATF is essentially a hydraulic oil...
I have a Williams (machine & tool co) in tank hydraulic pump that uses ATF rather than regular hydraulic fluid...
I once bought an old Delta 88 Oldsmobile that had been a one-owner by a priest, he kept a detailed log book of the service, he had done on the old car, it had 162000 miles on it. Noticed in the logbook, no mention of ATF changes, so I took it in to have the fluid changed, when the pan was dropped, in the black sludge and totally black oil was the little plastic plug they put in the dipstick hole, which normally is taken out with the first change, and cleaning of the pan.. well this was its first! Turbo hydra-matic 400 is pretty tough, but 162000 is a little far between changes if you ask me:laughing:
The old transmission still worked, but it was a "slushamatic", lots of "slippy,slippy" on gear changes.. "I wonder why?
James K0UA
Old blue shifts great. Dove her today. At about 75,000 miles I asked my mechanic who I have used for years to service the transmission. He told me that he would not recommend it that if I had serviced it as recommended it would be fine but that he had seen several Ford transmissions that had gone over 50,000 miles before the first service begin to give problems after servicing.
Those commenting about ad pack coming out of solution: have you ever found this? Bet not. There isn't much additive in ATF. It's THE most highly refined dino oil, at least it was when I worked my 31 years in the lube oil industry as a chemical engineer. Being so highly refined, it doesn't need many additives.
Like I said, I've used plenty of old ATFs, even ones that had been sitting partly used (for power steering fluid in my vehicles; don't have any of those AT vehicles) mixed in diesel and ran in my JD 4010 and in our 1983 Benz. The Benz has been sold now. I can't do this in our 2010 VW TDI with it catalytic converter, etc. The 4010's fuel tank is still fair game.
Ralph
It is indeed. Some of you are taking the comparison far too seriously. ATF goes bad if it sits in an unopened container, just like milk. It takes longer, but it happens. If you don't believe me pick your favorite lube manufacturer and email them about the shelf life of their ATF, they will probably tell you 5 years or so, give or take, and offer a long explanation why specific to their fluid and packaging. You make it sound as if all ATF is the same, there are many many different kinds and the additives are what make up most of the difference. Generally if you use the wrong ATF in the wrong trans you'll ruin it. Old ATF would be considered "wrong" by both the fluid manufacturer and the transmission manufacturer.Oil in an unopened container is not the same as milk.
Problem is that the engineers forget the old formulas, so they have to devise new specifications. :laughing:
Exactlys :thumbsup:I think of it this way. It took Mother Nature millions of years to make the oil, I doubt it would "go bad" within our life time.
