Raspy
Veteran Member
- Joined
- Dec 16, 2006
- Messages
- 1,655
- Location
- Smith Valley, Nevada
- Tractor
- NH TC29DA, F250 Tremor, Jeep Rubicon
Once she has some training and some experience at a range, she'll probably start gravitating toward either a small auto or a revolver. If it is likely to lie around with little use and get little maintenance over time, look at an LCR. The simplicity and ease of use makes them very attractive. If she gets an auto make sure you decide in advance if it will always have one in the pipe or not, be on safety or not, be cocked and locked or not, etc., so there is no confusion if it's needed in a hurry.
If she doesn't shoot for fun and will only use it enough to get some practice, I recommend, again, the LCR. No gun could be simpler, lighter, easier to understand and use. She might like the LCR 357. Same exact size as the 38, but made of stainless. It is a bit heavier than the 38 aluminum model, but can run 38 ammo to reduce the over penetration and recoil. These are very easy to shoot, require minimum maintenance, are comfortable and will last a lifetime.
The problem with the Bond arms derringers is they have a very awkward trigger and are only two shots. They are flat, but not easy to use. A better choice for flatness would be an M&P bodyguard 380. Double action trigger, so no cocked and locked. Re-strike capability. Light and small. Plus, they are more fun to shoot than an LCP, at least in my hands. Either of the micro pistols from S&W or Ruger conceal very well and are very light.
As usual with a gun thread, you'll get a lot of opinions. But this is about her and what she can learn to use and trust while being safe.
I also think it's better to have a different gun at home. Carry one and have another within easy reach at home. So she should be comfortable with both and the one at home can be more comfortable to shoot because it doesn't have to be easily concealed. If you choose a revolver to carry, like an LCR, you could choose a revolver at home too, with the same ammo and operating system. Or a Bodyguard 380 to carry and a 9mm auto with the same features at home. If you do choose a Bodyguard look at the two models of them. I have the newer one without the laser and think it's a better choice for carry.
I hope this thread doesn't devolve into a discussion about calibers. She doesn't need a 44 magnum concealed in her purse. But she does need something, so it must be easy to carry. If she leaves it home because it's inconvenient, and needs it, the caliber discussion means nothing. Even a .22 would be very nice to have in a bad situation.
