allen in texas
Platinum Member
- Joined
- Oct 26, 2007
- Messages
- 916
- Location
- Levelland, TX
- Tractor
- Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
"float" on your front end loader simply means that all the hydraulic pressure has been released from the lift cylinders and the FEL weight all rests on whatever it is attached to plus what is on it.. But you already knew that. Float really only serves a purpose (for me anyway) during back dragging. If I try to go forward with my bucket on the ground and the FEL in float, My front tires will be in the air in short order and that is with the bucket tilted back just enough so that it does not bite but just slides across the ground.
Now as far as using a snow plow, I haven't a clue since normally I don't see enough snow to have one but I tend to agree with everyone else that you would need to manually control the contact of your blade with your controls. 900 pounds plus the weight of the FEL is a lot of weight on those little skid pads. I'm sure it would be fine if you were clearing a paved parking lot but obviously, it doesn't work on gravel. The shoes just dig in. Good luck is about all I can offer.
