Jay4200
Veteran Member
- Joined
- Nov 23, 2005
- Messages
- 2,028
- Location
- Hudson/Weare, NH
- Tractor
- L4200GST w/ LA680 & BX2200D w/ LA211
So you say that it should be greased MORE than once every ten hours? BTW, You can wipe that excess grease off the loader
I do if I'm using it. If not, it doesn't need grease. If I was just pulling a rake or something and the bucket was just riding around on the front, I could drive around for 1000 hours w/o needing to grease the thing.
And I do wipe off the grease. Unfortunately, it's usually by accident with my shirt...
So do you grease every 10 hours or not... I'm a little confused here. Maybe this is why your loader is a bit loose? Not to mention snow gets packed into every nook and cranny, you let that snow melt to water and let that sit in the pins until it evaporates?
My loader is a bit loose because it has 2600 hours on it (PTO hours), and the PO (about 300 hours use) had a grease gun with a broken tip. It just squirted grease out w/o putting anything in the fitting. Evidently, it was like that for quite a while. He gave me the gun when I bought the tractor - first time I used it I was like, "uh oh". I pulled every pin on my loader and backhoe, cleaned the pins, bushings, grease fittings, and pin grease channels, then manually lubed each one before reinstalling. Lots of the pins were dry with the grease channel filled with solid gunk. Most of the pins were fine after cleaning up, however, with the exception of the lower pins on my bucket - they were worn about halfway through. I've since over-greased and haven't experienced any substantial additional wear on any of the pins/bushings. I'm even still running the half-worn pins in the bucket (they get grease every hour or two of use - 10 pumps to fill them up) - I finally got replacements after 6 years of forgetting - they are sitting on my bench ready to go, as soon as the weather climbs above freezing. Speaking of freezing, I'm not worried about melting snow - firstly because nothing has had a chance to melt yet, and secondly because a little water at the joint won't penetrate the grease. Even if it does, any metal will be well protected by grease, and the water will evaporate long before it has a chance to do any corrosion. It's surely not as bad as leaving it out in the rain, which I don't do either.
Whatever works for you. Every time my meter hits a "0"... I grease and my pins already have too much play, IMHO (6 yr/300 hrs) :confused2: even with greasing it a bunch with EP Moly.
Play at 300 hours? Really? That's odd. As for your 10 hour schedule, nothing wrong with greasing when you don't need it, however, if you are doing heavy loader work, even your 10 hour schedule may be inadequate - and if your pins are getting sloppy already...
I recently started using the Moly grease. Up until this year, I used regular HD (red) grease. If memory serves, I had to grease less often with the red grease, but I stopped using it mostly because it is not waterproof - turns a sickly light-brownish color after exposure to water. The black stuff doesn't wash off, but looks a lot worse when smeared on a shirt.
JayC
