130 feet between shed and house. had to run eletrical, water, gas, telephone, network, security cables.
i had a little 2" wide trencher that dug down about 2 to 2.5 feet. that you had to slowly crank a wheel to pull it along a rope.
the small little trencher took for ever. and it only had a little 5hp gas engine on it. (small push lawn mower engine basicly) it was a nice little trencher and for say telephone line or short runs it would be nice vs hand digging. but....
i then got a 555c loader / backhoe. that came with 24" backhoe bucket.
it ripped everything out nice and quick. my problem was. 130 feet between house and shed with some trees near by. i didn't have much room to work. and more to the point. i couldn't run the loader/backhoe. straight down the line. instead i had to work from this and that side. which ended up making the trench much wider than needed. granted it was alot faster and much easier than the little trencher.
i know i will be in a couple years having to put in some wires. 1/4 mile long. and when it comes to that. i know 90% of it, will all be a nice straight line. and if i still have the 555c loader backhoe. i will for sure go with a smaller size bucket say 8" to 10" vs the 24" a smaller bucket for straight lines would be awesome.
the one thing with a backhoe. is trying to to keep a nice smooth bottom trench. if the bottom of trench is all up and downs and you are laying in hard plastic pipe. you could crack pipes when ya go to back fill. or will require to put in sand and level the trench bottom out. before the pipe goes in.
i know for sure, i wouldn't recommend a backhoe. if it ment you had to switch seats for example a tractor that had a 3pt hitch backhoe on it. moving back and forth between seats as you moved along would be a nightmare.
i can't speak for other trenchers / ditch witches. never used them before. though if you didn't have a tractor. i would most likely get a ditch witch. that has the chain saw on one side, a small utitly backhoe on other side. and a small push blade on it. for pushing dirt back into the trench.
the little small utitly backhoes. could be nice running a couple trenchs from different angles. and getting a turn in, then using them to finish digging out the trench against a house wall. or like.
