Gatormade trailers still gets C grade
   / Gatormade trailers still gets C grade #21
Not saying this is true, but what if the OP is exaggerating the truth and ruining a company name for something that really isn't an issue?
That is why you read all recommendations & stories here on this website with a grain of salt.
As far as the trailer manufacturer goes, I did not name them in my posts as making defective trailers. I said "IF they use sctoch locks" or IF they don't paint the undersides of their trailers, they should not be recommended".
I'm pretty sure once the owner finds out what happened, our OP will be given satisfaction.
   / Gatormade trailers still gets C grade #22
I never said they were the best, I said they were a good trailer and a lot of bang for the buck. I still think they are one of the best trailers on the market.
Chris
If "Gatormade" is one of the best trailers on the market...They wouldn't have done a sorry job like this:rolleyes:
If they plan to be one of the best trailers on the market,.. then they better get their act together when building them.....OR they will be one of the worse trailers on the market.
But what I've seen in the type of wiring, paint and other things... I already believe their the worse trailers.
I know a couple people that bought those small single axle trailers from Lowe's to just use around the farm, and they have paint underneath and the cost of the trailer was cheap.
There is NO EXCUSE for this type of work from what is suppose to be one of the best trailers on the market:rolleyes:
   / Gatormade trailers still gets C grade #23
When I was shopping for trailers, I looked at Gatormade, among others, and the ones I looked at appeared were nice and offered excellent "bang for the buck" considering the prices they were asking for them. With that out of the way, I tend to lump Gatormade into the middle rung of new trailers. Lower rung new trailers tend not to be painted underneath and come with used tires. At the middle level, trailers are a lot like budget level trailers, but with new tires and maybe some paint underneath. At the top end, trailers are built heavier, nicely painted top and bottom, come with new (and often better quality) tires, and a price roughly 50% more than mid-range trailers. The key to being satisfied with the deal is going into it knowing what to expect and knowing what you're getting for your dollars.
My personal trailer is a Hurst--I'd put it about on par with a Gatormade, maybe not quite up to the ones I looked at. It's painted top and bottom and came with new tires. It's great at the price I paid, but hardly the best. I'm not disappointed because I knew what I was getting--it wasn't a $3500 trailer, but it didn't cost that much either. I consider Hudson Bros. trailers to be top tier (maybe not as pretty as some, but all I've been around have been really well built), and that's what I would've bought if I'd been buying for business or if money weren't a motivating factor.
All of this is to say, if you have a defective trailer, you shouldn't have to accept it, but if there's a problem you can easily correct yourself, you'll probably be money and frustration ahead to do it and chalk it up to experience. Good luck and I hope you get an outcome you can live with.
   / Gatormade trailers still gets C grade #24
That's a new one on me. Never seen a new "budget" trailer with used tires and no paint underneath.
What's this world coming to? Who would buy a new trailer that didn't come with new tires and paint on the bottom for crying out loud. :confused:
   / Gatormade trailers still gets C grade #25
Builder--you're using your equipment to make money, so you're not looking specifically to save a buck on your equipment. You're looking for equipment that won't cost you 1000's due to downtime, hence you may have missed the low end trailers on the market.
There are a lot of low end trailer manufacturers that build a trailer, squirt the easily visible outside surfaces with paint and slap a set of used car/truck tires on it and then sell them at pretty low prices. Folks that just want a trailer at a low price buy them and are willing to overlook their shortcomings due to the price (and hopefully the purchaser's intention of limited use).
I'm not saying it is or isn't a smart thing to buy 1 of these--just saying they're out there. Mostly smaller "manufacturers."
   / Gatormade trailers still gets C grade #26
75% of the trailer stores around me sell brand new trailers with used tires, non-treated decks, no paint underneath, no brakes, etc. Just in the past year I have noticed they are not using used truck wheels but instead using the new white spoke wheels. These 6.5 x 16 trailers were selling for $650 five years ago and are about $950 today.
   / Gatormade trailers still gets C grade #27
I see these trailers all of the time. Usually old steel car wheels - usually 14" with old pretty worn car tires. If you were lucky they painted the steel on the trailer - on the top side. Maybe or maybe not painted it before the wood was in place. Most likely then didn't cover the wood to prevent over spray - but don't completely paint the wood either. Usually a real thin safety chain - yes one that is maybe run through a loop on the tongue of the trailer so that if one link breaks you have nothing. Chances are it isn't treated wood either. Yep, I passed on these trailers and went with my Gatormade. It isn't even close to the same league as these "low end" trailers.
Not saying there isn't a market for these trailers, because for the number of them out there, somebody is buying them.
   / Gatormade trailers still gets C grade #28
Same thing here. Of course you can get new tire upgrade but for most the tires will dry rot off in 4-5 years, way before they wear them out. Figure the average guy only drive with his trailer 500 miles a year or so.
I bought mine new in 2004, a 18' x 82" wide, utility trailer with a used 15" 205-75-15 wheels and tires, a spare, and 5' long ramps for $860 out the door and some of that was a delivery fee to get it closer to my house. I think it was $820 without the delivery. It has 2 welded on safety chains that are properly sized and a 8K coupler. Its painted entirely, including the wood deck. I just had to replace the tires last year due to dry rot. Never had a flat except for a nail I picked up at a lumber yard. It hauled many cars and SUV's with those tires making 3 trips to Chicago, 1 to Detroit, and multiple back and forth to the lake and my dads house about 150 miles round trip.
Chris
   / Gatormade trailers still gets C grade #29
Go figure,my new 16 ft Hurst trailer I bought back in 2002 was JUNK,scotch locks,bad welds and so on,my fault for not being more observant when I purchased it,maybe it was made on a monday or friday.I sold it and bought a 20ft.PJ trailer and have been more than happy with there quality.coobie
   / Gatormade trailers still gets C grade #30
I don't think they make a better trailer than P&J.....I've been real happy with mine also.
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
