Yanmar 2_29 4.80 star(s) (4)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Yanmar 2_29.
Under 25 HP Tractors
About the Yanmar 2_29
Yanmar 2_29 Discussions (13)
Here are the most recent 2_29 topics from our community.
  1. P
    Yanmar 1510 steering drag link
    Hey guys, I bent my steering drag link real bad on my old Yanmar 1510. Home Tractor Parts doesn't have one in stocker in their boneyard, and they can't tell me to use one from a different model...
  2. P
  3. K
    Yanmar 1510 Issue
    I have a 1510 that cranks right up and PTO works fine, but will not move. It acts like it is going into gear and barely moves about 6 in. All rear tires roll freely, and brakes works fine as well...
  4. K
    Buying Advice Yanmar 1600 or Yanmar 1510
    I'm looking for a small tractor to keep up my property and looking at two tractors locally: 1 = Yanmar 1600 w/196 hours 2 = Yanmar 1510 w/220 hours Just wondering if anyone could give some...
  5. K
  6. W
    Yanmar 1510 with stump grinder
    Thought some of you might find this interesting. making a stump grinder part 2 - YouTube He has several videos. Making of a stump grinder and using the stump grinder - YouTube
  7. P
    yanmar 1510 steering knuckle
    Anyone know if i can buy just a ball and tube kit for the steerring knuckle on a 1510. Or kbow the size of those balls?
  8. P
    yanmar 1510 manual/rear-end question
    Does anyone know anywhere to get a pdf manual for these tractors. Also, I have a whining noise that seems to be coming from the left rear wheel or that general area. Any suggestions to what it...
  9. T
    Buying Advice Yanmar 1510 D
    Just got roughly 2 acres to landscape and garden Looking at a Yanmar 1510D with tiller, scraper box, and loader. They are asking $6,500 Tractor started right up and sounded good..... It was on...
  10. Y
    Yanmar 1510 Problems going into reverse...
    I have an occasional problem getting the tractor to go into reverse. When shifting into reverse sometimes I will have to move shift lever all the way forward into the highest gear and then return...
  11. Y
    need PTO shaft/yanmar 1510
    howdy I am looking for a new/used PTO shaft for my Yanmar 1510 tractor. is there anyone out there with a used part or new off the shelf? I have been lookin since may 06!!
  12. C
    Looking at a Yanmar 1510 need specs
    i found a Yanmar 1510 in the paper, all it says is that it's 2 WD comes with 4' yard bax and weights. I can't find any good specs online. Does anyone know if it comes standard with a PTO, 3...
  13. J
    Yanmar 1510 Manual
    Some benelovent benefactor gave my cousin (really, not me ) a Yanmar 1510 (I think) that won't run too well . We pull started it but it has no power and smokes like crazy . We sure could use a...
[ad placeholder]
User Reviews (4)
Read what TractorByNet members think about the Yanmar 2_29 Subcompact Tractor
5
75 %
4
25 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
TDSmith
2_29 Yanmar
Yanmar YM1510
Model Year: 0
My father-in-law gave me this tractor because his health is declining and he could no longer use it. I haven't had it long enough to judge how good a tractor it is. So far I have been trying to put it back together correctly. Found bolts missing and wiring messed up. The engine is impressive. Starts quickly and runs smooth. We don't have a manual for it yet but plan to get one soon. Found a lot of things my Father-in-Law was doing wrong that a manual would have helped.
Pros: Great little motor.
Cons: Front wheels are set too far back.
5.00 star(s)
trky
2_29 Yanmar
Good O' Yanmar
Model Year: 1979
I have put over 100 hrs. on it and not one bit of trouble.
Pros: Good reliability for the money.
Cons: Some of the models are hard to find parts for.
Photo Uploads:
5.00 star(s)
trky
2_29 Yanmar
Yanmar 1510 Two Wheel Drive
Model Year: 1979
Yanmar 15104' box blade/4'bush hog/PTO stump grinder/front end loader /4' tiller ''bush hog ''name brand...bigger rear tires R4 on 12'' rims.
Pros: Very dependable and affordable.
Photo Uploads:
5.00 star(s)
camshaft11
2_29 Yanmar
Yanmar 1510 2wd
Model Year: 1979
This is a great little tractor for home use - strong. I love the shifting no clutch the only thing that isn't the best its so light will do grading and bushogging just fine. Don't like the teeth on a box blade also good idea to add the weights to the front.
Pros: Shifting.
Cons: Weight.
[ad placeholder]
Yanmar 2_29 Owner Pages
View owner pages to see photos, customization and comments about member-owner Yanmar 2_29s
Yanmar 2_29 Community Rankings
#80 user rating of 731 Under 25 HP Tractors items
#107 Viewed of 731 Under 25 HP Tractors items
#113 discussed of 731 Under 25 HP Tractors items
#637 user rating of 19625 items overall
#753 Viewed of 19625 items overall
#721 discussed of 19625 items overall
Highest Rated in This Category
    No results found.
