John Deere 720_3 Reviews
5.00 star(s)
ijt720
720_3 John Deere
John Deere 720 Deisel Electric Start
Model Year: 1958
I only gave reliability 4 stars because of the finicky 24 electric system, which when set up works fine. It just took school work get right. And harder starting when cold.
Pros: Fuel efficiency, heavy duty build, easy to work on, good weight balance.
Cons: Hard cold weather starting.
5.00 star(s)
Bubba331
720_3 John Deere
A Must Have
Model Year: 1986
This particular tractor is a must have for farmers who use older generation John Deere very reliable hp rated at about 80 will pull a 5 bottom plow with ease.
Pros: Reliable.
Cons: Sucks the diesel.
5.00 star(s)
JD720
720_3 John Deere
A Good Workhorse!
Model Year: 1956
I own several older John Deere 2 cyl models - all are in various stages of restoration - but the best one of the whole bunch is my 1956 John Deere 720 Diesel. This tractor has remarkable power and fuel efficiency for its size. Mind you its an old tractor, and they are not built anymore, but in there day the 720 was a big tractor! A little bit of advice though, you must have quite a bit of mechanical knowledge if you want to own a tractor like this. The 720 is not the easiest tractor to operate, as the main engine is started via gasoline powered pony motor. These can be quite troublesome at times, and require a great bit of skill to work on. Parts are not easy to find for the pony motor, and when you do find them you better have a deep pocket! But for the most part, the 720 Diesel is a joy to own and operate, and has plenty of power and weight to do most any job you throw at it.
Pros: Fuel economy, power, stability, & value.
Cons: Parts availability, noise, & starting engine.
