John Deere 720_3 5.00 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 720_3.
50-100 HP Tractors
About the John Deere 720_3
John Deere 720_3 Discussions (6)
Here are the most recent 720_3 topics from our community.
  1. Dedaisy
    Buying Advice John Deere 720 Mo/Co
    Looking for some advice on a John Deere 720 Mower/Conditioner. I believe that it is about 1995 unit with a sickle bar cutter. What show I look for and what are the pluses and minuses? Thanks..
  2. F
    John Deere 720 parts needed,
    My Uncle is looking at a John Deere 720 that has no 3 point hitch arms, all that is there is the rockershaft, Does anyone know where we could get all the parts to install the 3 point hitch on this...
  3. I
    JD720 D INJECTORS?
    HELLO HELP! Running my 57 720D down the road and stops running right. Found that the cotter pin in the decompression control rod was missing and therefore I was running without compression for a...
  4. J
    John Deere 720
    I have John Deere 720 that blows smoke out of the oil cap on the side of the tractor and there seems to be alot of pressure there. I tried a to put a breather on it but it didn't seem to help. Is...
  5. R
    john deere 720 diesel with pony start, oil in antifreeze
    I have a john deere 720 diesel with pony start that I am restoring. I have oil in my antifreeze. I am sure it is from the diesel motor, not the pony motor. any advise?
  6. B
    JD720 diesel coolant in crankcase
    I have a 720 with a starting engine I'm getting coolant in the diesel engine crankcase Wondering how to find out if it's coming from the pony eng. or the diesel.How do I know if the...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the John Deere 720_3 Subcompact Tractor
5
100 %
4
0 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
ijt720
720_3 John Deere
John Deere 720 Deisel Electric Start
Model Year: 1958
I only gave reliability 4 stars because of the finicky 24 electric system, which when set up works fine. It just took school work get right. And harder starting when cold.
Pros: Fuel efficiency, heavy duty build, easy to work on, good weight balance.
Cons: Hard cold weather starting.
5.00 star(s)
Bubba331
720_3 John Deere
A Must Have
Model Year: 1986
This particular tractor is a must have for farmers who use older generation John Deere very reliable hp rated at about 80 will pull a 5 bottom plow with ease.
Pros: Reliable.
Cons: Sucks the diesel.
5.00 star(s)
JD720
720_3 John Deere
A Good Workhorse!
Model Year: 1956
I own several older John Deere 2 cyl models - all are in various stages of restoration - but the best one of the whole bunch is my 1956 John Deere 720 Diesel. This tractor has remarkable power and fuel efficiency for its size. Mind you its an old tractor, and they are not built anymore, but in there day the 720 was a big tractor! A little bit of advice though, you must have quite a bit of mechanical knowledge if you want to own a tractor like this. The 720 is not the easiest tractor to operate, as the main engine is started via gasoline powered pony motor. These can be quite troublesome at times, and require a great bit of skill to work on. Parts are not easy to find for the pony motor, and when you do find them you better have a deep pocket! But for the most part, the 720 Diesel is a joy to own and operate, and has plenty of power and weight to do most any job you throw at it.
Pros: Fuel economy, power, stability, & value.
Cons: Parts availability, noise, & starting engine.
[ad placeholder]
John Deere 720_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 720_3s
John Deere 720_3 Community Rankings
#1 user rating of 1508 50-100 HP Tractors items
#279 Viewed of 1508 50-100 HP Tractors items
#149 discussed of 1508 50-100 HP Tractors items
#1 user rating of 19625 items overall
#1839 Viewed of 19625 items overall
#1028 discussed of 19625 items overall
#11 Ranking of Most-OwnerPages in 19625 items overall
