Kubota BX2660 Reviews
5.00 star(s)
Anonymous Poster
BX2660 Kubota
Awesome Tractor For The Size
Model Year: 2007
I have had my BX2660 for maybe a little over 10 years. I mow a large property and use the front loader all the time to landscape and move dirt, rocks, wood, etc. I have beat the crap out of it, never clean it, and am very bad at maintaining it. But I have got to tell you, I would buy this tractor again, only maybe a little bigger one. It is incredible what this thing can do - lift, pull, push, etc. A John Deere would be destroyed by now. I know because I destroyed one before I had my Kubota. I just changed the oil with the last change being 5 years ago. You have to keep the fuel filters clean though, as that could cause issues.
Pros: Can't seem to destroy it
Cons: None
5.00 star(s)
Old Coot
BX2660 Kubota
Lot's better the GR2110
Model Year: 2011
After so much trouble with a GR2110, I traded it on the BX 2660. All though it does tear up the grass on sharp turns it does everything else well. Lot of power and traction. Much faster then the GR. It does have a lot of gear noise but tolerable.
Pros: Does everything I ask it to do.
Cons: Does tear grass on sharp turns in four wheel drive.
4.00 star(s)
Popfizz7
BX2660 Kubota
BX2660 Re-Review
Model Year: 2008
This is an update to a previous review. Here is my previous review: Overall good tractor. Bought new in 2009. Kubota service severely lacking. Thank goodness for the dealership. Tractor has excellent power and has done everything I have ever asked of it. I mostly mow (6 acres or so) with the occasional grading of the gravel driveway (1600 ft). Have had multiple oil leaks. Some severe. Broken engine mounts---3 times to be exact. Another complaint I have is that it is that everything about this tractor is loud. The engine/exhaust is loud, the hydraulics are loud an the mowing deck is loud. New additional info: The motor mounts recently broke again. The dealer replaced them again. The new mounts are a little different from the previous ones they installed. They now have "hard stops" welded to them to minimize the engine shake during startup and shutdown. I was told this issue is atypical....but I cannot help wonder why Kubota redesigned the motor mounts for an atypical problem....Anyway, the dealer has continued to make these repairs at no cost to me. Kubota has been picking up the tab. Also, my last review says I gave everything 5 stars. Not sure what happened there, but I know I didn't give everything 5 stars. I will rate accurately again and see what happens. If this review shows stars, then someone is tweaking results.
Pros: Powerful.
Cons: Loud and noisy. The hydraulics are loud, the engine is loud, the MMM is loud. I would also like to add that it seems to vibrate a lot, no matter what RPM the engine is running.
3.00 star(s)
Anonymous Poster
BX2660 Kubota
Poor Reliability
Model Year: 2000
My BX2660 has been in the shop more than I've actually used it. If I had the funds I would sell it and buy something else. I've lost two transmission cooling fans before I found out that there was a guard that probably should have been on the tractor from the start and wasn't. Since I got it out of the shop the last time it does not have the power or speed it had before it went into the shop.
Pros: I don't have much good to say about the tractor.
Cons: Been in the shop more than it's been out.
5.00 star(s)
juanmotime2k
BX2660 Kubota
Don't Tell It How Small It Really Is!
Model Year: 2010
I bought this for usage around the house, about 1.5 acres. Front end loader and mid-mount 60" mower was all it had. Also had an additional 33 acres of mixed wood and grassland to maintain. WOW---what a machine! I added teeth to the bucket and coupled with a 60" bush hog this thing is unstoppable. I had it in some very delicate situations a few times, added a skid plate after tearing up the transmission fan ($$$), but by far this little machine is steroid driven. Lately, I coupled a PTO generator for emergency use and it performs flawlessly, even runs the house a/c if I need it to.
Pros: See review.
Cons: Needs a better way to couple the mid-mount mower PTO to hold it in place until secured.
5.00 star(s)
Popfizz7
BX2660 Kubota
Kubota BX2660
Model Year: 0
Pros: Good power.
Cons: Loud, vibrates, Kubota Service lacking, seems to use a lot of fuel.
5.00 star(s)
lastmanse
BX2660 Kubota
Kubota Strong
Model Year: 2013
The BX26660 is my second Kubota. I am absolutely sold on Kubota tractors and this new baby is no disappointment. With only 3 1/2 acres of hilly overgrown forest (read that to mean the density of saplings is incredible) I knew a small tractor was necessary for maneuverability. The FEL works like a champ and the whole package performs better than I expected. Why buy new for only 3 1/2 acres? I don't ever plan on buying another tractor or riding mower again.
Pros: Maneuverabilty, Dragging Power, Size.
Cons: Lateral Stability - but any tractor is going to have that when working on hillsides.
5.00 star(s)
jkrey
BX2660 Kubota
Kubota BX2660
Model Year: 0
Tractor has been a back breaking life saver. Bought two acres with alloy of grading and dirt moving. I am doing things on this that I never thought possible. I love this tractor.
Pros: Fits in small spaces, powerful for size.
Cons: Wish had more ground clearance.
5.00 star(s)
mrgurkha
BX2660 Kubota
Novice
Model Year: 2012
Hi thanks, for checking out my review. This is my first tractor and I really love it. I did a lot of home work, research and inquiring of friends. I owned a Kubota lawn mower which was built tough, but I wanted something to drag my driveway. The BX 2660 is easy to attach implements, front bucket and box scrap. The belly mower come out the side easily in about 10 min. Just turn the anti-scalp wheels and it rolls out, driving over it like a Deere can't be good. I can get on it from either side and the controls are easily accessible. I mow a two acre front yard in about half time.
Pros: Strong for the size, easy use, 0% finance, built like its big brothers.
Cons: None yet.
5.00 star(s)
joebrocato
BX2660 Kubota
Better Than a Bass Boat
Model Year: 2010
I am a first time tractor owner. I have a 3 acre home site that is quite hilly and has a gravel road, and a 10 acre horse pasture to maintain. I bought the tractor primarily to mow the grass and to maintain the road. I got the Kubota 2660 with the front end loader, mid mount mower, a box blade and a 4' land pride brush mower. Since then, I got a backhoe, and a tiller. I never realized how much I would use this tractor just for the fun of it. I even mow the street shoulders for about 600 yards to the highway just because I can and it is so easy. I thought I would have no use for the loader, but now, I don't know how I could get along without it. The 2660 has plenty of power to operate the implements including the backhoe and to do just about any task that I try. I added a rv winch, a power inverter, and a hitch ball on the loader. Moving stuff around my place and operating small hand tools without having to drag out long power cords is now easy.
Pros: Easy to operate, always starts, plenty of power to climb hills and operate implements.
Cons: Not maintenance friendly, and some of the plastic parts break easily.
5.00 star(s)
KG76
BX2660 Kubota
Go Kubota
Model Year: 2009
Bx2660 is a great tractor for its size and class.
Pros: Good little work horse.
Cons: None.
5.00 star(s)
gsmaneeley
BX2660 Kubota
BX2660
Model Year: 2012
I looked at many different makes and the Kubota fit my needs. I had a good experience from the dealer which was also a big consideration. I have had a few questions and was helped both in person and over the phone.
Pros: Nice ergonomics for me light the quick hitch in the front.
Cons: Little light in the rear when using FEL. Needs ballast of some sort.
5.00 star(s)
Anonymous Poster
BX2660 Kubota
Good Tractor
Model Year: 2011
Got this tractor last year as a birthday gift. It has front end loader, rear four foot mower, has plenty power. The only thing I don't like is it does not have position control on the 3 point lift. It's a pain to get the mower or any other 3 point equipment back to the same height every time it is moved. And be careful(!) if you drive over some tree branches or they will break the transmission cooling fan. A $700 replacement job. I built a guard to cover the under side of the tractor to prevent that from happening again beside that, it is just what I need.
Pros: Plenty power; right size for the house yard; easy to use.
Cons: No position control; needs larger trans fan guard.
5.00 star(s)
jctrabue
BX2660 Kubota
BX2660 Review
Model Year: 2009
I bought this tractor with a front end loader, 60 inch mower deck, and box blade. I own 3 acres which needed to be cleaned off (a lot of brush on it). Once I got it cleaned off, I plan on using it mainly for mowing, snow removal, and other small jobs. It is a great little tractor but does have some problems. I owned it two days before I broke the cooling fan for the transmission which is mounted on the drive shaft on the underneath side. There is also a filter for the transmission mounted on the underneath side of the tractor. There is absolutely no protection for any of this. In order to repair the fan you have to unbolt the engine and move it forward so the fan can be replaced on the drive shaft. The grease zerks on the wheels on the mower deck do not stay in the wheels. When you grease them the grease zerks usually pull out of the wheels when you try to take the grease gun off them. Also when I bought this tractor the front tires (bar type) would not hold air. About every two or three days they would go completely flat. They were repaired twice without any success. They finally replaced both the tires and rims which took care of the problem. Overall I do love my tractor and am glad that I bought it. It has plenty of power for what I need. The mower deck does a great job but is a little difficult to grease while on the tractor. Bought from a great dealer (Crown Power and Equipment in Eldon, MO). I bought it right from them and they took care of my warranty needs without a problem.
Pros: Great tractor, lots of power, 4wd comes in handy and is needed for certain jobs.
Cons: Transmission cooling fan & transmission filter need protection from getting damaged. Grease zerks on mower deck wheels need to be improved. Low clearance to ground.
5.00 star(s)
geifried
BX2660 Kubota
So Far So Good
Model Year: 2009
Works as I want it to.
Pros: Powerful.
Cons: Whines.
5.00 star(s)
rj1955
BX2660 Kubota
Kubota 2660
Model Year: 2011
Purchased the tractor along with a 60" deck mower and front end loader. Also purchased a scraper box and added teeth to the bucket. This little machine had been put through the test, both moving a hill slide from the road and mowing. It has performed flawless. The teeth on the bucket really make digging much more efficient. It is a great machine and the controls are very user friendly. Would not hesitate to recommend this Kubota 2660 to anyone. It also mows great, better than my JD 235.
Pros: Well built machine, great ride and handles smooth.
Cons: Needs small storage compartment. Tight fit when removing mower deck.
5.00 star(s)
JimRice2
BX2660 Kubota
Kubota BX2660 w/FEL 60" Mower Deck
Model Year: 2010
My Kubota is an excellent machine for the homeowner with a large lot to mow, landscape and garden. My wife uses the front loader to spread mulch and to assist her in planting the many landscaping plants she has installed since buying our new home. I bought a single bottom plow which I use to plow the garden, disc and mow the 1.9 acre lot. Highly recommend it for home owners. The only complaint I have had is with the dealer I purchased it from not having a dedicated staff to service my Kubota. That is no reflection on the machine, only the dealer.
Pros: Excellent machine, does all expected plus some.
Cons: Dealer service department.
5.00 star(s)
John Ward
BX2660 Kubota
Kubotta BX2660
Model Year: 2011
Great piece of machinery. Very good dealer experience (Emerich- Charlton, NY)
Pros: Like the FEL.
Cons: Tach is hard to read-needs to be larger so we boomers don't have to wear glasses to read it.
5.00 star(s)
David M
BX2660 Kubota
First Tractor
Model Year: 2009
Of course, have had the mass market "garden tractors," but now that I've had this Kubota, I know those store variety aren't real tractors. Anyway, pleasantly surprised at the utility this machine gives me even on just my lot in town! I really got it for country property but haven't even used it there yet. I really like this machine.
Pros: Strong, well built, quiet, easy to self service most things, zero percent interest.
Cons: No lights to the rear, turn signals too easy to destroy in hedges, $$$.
4.00 star(s)
Popfizz7
BX2660 Kubota
BX2660 Review
Model Year: 2008
Overall nice tractor. The front tires are junk (bar). Had some hydraulic leaks that should never have happened. Also had a broken motor mount (factory failure). The tractor has good power overall and a comfortable seat. I wish it had a built in storage compartment somewhere for a few tools.
Pros: Adequate power, comfortable seat.
Cons: Reliability not quite what it should be. Poor quality front tires (bar). Speed seems slow.
