Jinma JM-224 4.10 star(s) (11)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Jinma JM-224.
Under 25 HP Tractors
About the Jinma JM-224
Jinma JM-224 Discussions (79)
Here are the most recent JM-224 topics from our community.
  1. S
    Jinma 224 Head Gasket
    Hello all, I am reaching out through the forum seeking help. So here goes; I own a 2002 JINMA 224 no FEL though it does have the hydraulic line QC for one. I bought it new, may have had 2 hours...
  2. J
    Jinma 224, complete loss of steering.
    My tractor has always had the steering go mushy unless the hydraulic fluid was completely full, and last night it went out completely. I think i may have two issues. The first is the above...
  3. R
    Jinma 224 Radiator swap
    Good Morning. Needing to replace the radiator in my Jinma 224. Anyone no of something that can be swapped in besides the Jinma replacement? Thank You and be safe
  4. K
    Super Cheap Jinma 224 with a TY290
    I'm buying a 224 with a Koyker 150 loader.. Its a 99 Model with less than 200 hours on it.. HOWEVER, the Engine oil was neglected, shows none on the dipstick, and is seized.. There isn't any oil...
  5. J
    Jinma 224 Differential Lock lever snapped off.
    Its actually always been snapped off since i got the machine, and im finally tired of getting stuck due to no differential lock available. I got a new lever from Tommy a while back, and i was...
  6. N
    Rhino/Jinma 224 - 2 or 3 cylinders?
    I own a Jinma 284 that has truly been an economical work horse for me. I am looking at a Rhino on Craigslist with a 2 cylinder engine that I am certain is a Jinma. I contacted the owner to ask...
  7. R
    Jinma 224 Slow cranking,
    Hi Guys, Have an '03 Jinma 224. It was idling okay and then just stalled as if the fuel was turned off. Seems to have fuel to the banjo bolts at the injectors. Thoughts? While trying to start it...
  8. T
    JINMA 224 QUESTION
    I have a Jinma 224, model year 2005, its got shuttle shift and its 4WD. I cant get into 4WD, the lever moves but I cant feel it going into 4WD. Is there a roll pin there like there is on the...
  9. J
    Jinma 224: my dry clutch is well... wet, splitting guidance?
    Popped off my loader on the jinma 224 the other day (that was an ordeal... those kickstands dont work for crap) to finally adjust the clutch that had been slipping under load. Found not only a...
  10. J
    Leaking Jinma 224 Radiator (video inside)
    was moving some mulch yesterday, and noticed my temp was getting into the red, immediately shut down when it was about 110 (not sure if that gauge is C or F, i presume C), and checked my fluids...
  11. T
    Jinma 224 electrical problems....voltage regulator?
    The problem is: Tractor starts with authority. MPA gage goes pegged to red. Battery light is on. Run the tractor for 10-20 minutes, then MPA gage backs off a bit, but still high. Battery...
  12. J
    Fluid changes and maintainance for old Jinma 224?
    Good morning all, I made another thread a minute ago about the Jinma 224 I just bought. The price was right, but this thing was not maintained well in any way, and has a LOT of hours. Im...
  13. J
    New to me Jinma 224 : Slew of repairs (throttle, clutch, electrical, ignition, 3pt)
    So, my very first real tractor has fallen into my hands. An Iron Horse 224 with a FEL. It has significant issues, but does run well and the price sure was right. I got the whole package for...
  14. T
    jinma 224 front tires
    Hi Can I change the tire size on my 4x4 , jimma 224.The reason I am asking is I ordered a tire for the front. The original tire height was 24 inches when mounted but the one I ordered is 22 1/2...
  15. T
    jinma 224 steering problems
    Lost the steering on my tractor but only on the right side turn .It steers great to the left. If it was a bypassing cylinder would I not have lost the steering on both sides. I have the steering...
  16. T
    Jinma 224 looking for filters
    I purchased a 1997 Jinma Tractor about a month ago.It has a TY 295X engine.I am looking for an oil filter for this tractor and having a difficult time.When I bought it it had a motomaster filter...
  17. J
    electrical trouble jinma 224
    I have read many posts here about electrical issues. Most are ground related. I suspect mine is the same. I suspected a bad key switch at first. I have ruled that out. My trouble is #5 (amp...
  18. J
    Blown 30 amp fuse Jinma 224
    I have a Jinma 224 with about 600 hrs on it. I was mowing last Sunday for around two hours. I stopped to eat lunch, then tried to start the tractor. The 30 amp main fuse was blown. I was out in a...
  19. W
    Jinma 224 Glow Plug Fuse Blows
    Hello there I'm have startingproblems to! I have a Jinma 224 and when I use the preheating the 30Amp fuse is blown after a few seconds. Can this mean a defective glow-plug? Anyone who got an...
  20. J
    jinma 224 w/600 hr pto clutch adjustment
    I had a problem with grinding when engauging the pto. I got the clutch adjustment procedure from other post here. I tightened the pto adjstment bolts #6 about 1/4turn that fixed the problem . I...
[ad placeholder]
User Reviews (11)
Read what TractorByNet members think about the Jinma JM-224 Subcompact Tractor
5
27 %
4
55 %
3
18 %
2
0 %
1
0 %
5.00 star(s)
Anonymous Poster
JM-224 Jinma
Pushed Beyond Its Limits
Model Year: 1994
I have run this little guy way beyond anything that could be expected. We have rocky hillside acreage and I have broken one of the gears in the front 4-wheel drive. I ordered the gear and replaced it in the field. I've bent the bucket the load was so massive. I've cut the tires on rocks. I can't begin to count how many obstacles it's been over without fail. Currently the 4-wheel drive is out, but I'm in the midst of a project that prevents me from repairing it, even though I had to temporarily disconnect the front 4-wheel drive shaft, it still performs exceptionally! The tractor is easy to repair, the parts easy to obtain, and it's a great tractor. I'd highly recommend this machine!
Pros: Outstanding performance, great tractor
Cons: My only regret is not getting a tractor with more horse powe
5.00 star(s)
Anonymous Poster
JM-224 Jinma
7 years and 310 hours
Model Year: 2007
Looking back my Jenma 224 has been a good investment. Usual maintenance minor repairs and dependable service. Works well to have a garden, yet small enough to work in tighter areas. Have most attachments but use front bucket the most.
Pros: dependable
Cons: soft rubber tires dont do well in thorns.
3.00 star(s)
mnor690
JM-224 Jinma
A Lot of Tractor for the Money
Model Year: 2006
Bought new in the box. Came with a loader. Paid 6,500. Had to put it together. Has some nice features: 2 stage clutch, 2 speed PTO, rear hydraulics, 4WD, 3 point hitch. Had to replace starter and battery and all the fluids and filters. The good thing is, parts are available. I am a member of CTOA-Chinese Tractor Owner's Assn. All questions on these tractors answered, and dealers where parts are available. The tires tear up the lawn, and there is no underbelly mower available. It is heavy and powerful. I push down trees with the loader. The electrics are not reliable.
Pros: Cheap to purchase.
Cons: Unreliable electrics.
4.00 star(s)
noble12
JM-224 Jinma
Iron Horse Tractor
Model Year: 2006
Replaced pressure plate since has been good.
Pros: Runs good.
Cons: Parts mostly on line.
4.00 star(s)
Mike Tipton
JM-224 Jinma
Jinma 224 Diesel
Model Year: 2008
Has many features and does a good job for my application. I have a front loader and most of the other usual attachments. For a lot less money than a new comparable name brand tractor, and I have checked, I am well satisfied with my tractor.
Pros: Compact size, have a front loader, good size to use for a garden.
Cons: Soft rubber tires can get thorn flats easy.
4.00 star(s)
Mike Tipton
JM-224 Jinma
Jinma 224
Model Year: 2008
For my application the Jinma 224 is very good. I use it for a garden every year. I have most of the attachments and use the front loader and tiller the most. I use it about 50 hours a year with general up keep.
Pros: A lot of accessories for the money.
Cons: Minor hydraulic seal leaks.
4.00 star(s)
Mike Tipton
JM-224 Jinma
Jinma 224
Model Year: 2008
Serves my purpose just fine. Use the front loader the most, then the tiller. Have most of the attachments available. Only the usual maintenance.
Pros: Ag tires better for garden use.
Cons: Could use a little more power.
5.00 star(s)
Mike Tipton
JM-224 Jinma
Overall Info On My JM224
Model Year: 0
Average 50 hours a year. Kept under a metal carport. I change the oil every 50 hours and has required only the usual maintenance. I had to change the lower radiator hose and must keep the radiator clean. I use the front loader the most and I have a mower, box blade, road scraper, auger, and tiller. I have a garden every year and I use a Yanmar tiller. This tiller is good for the sandy soil I have. I like the narrow rear tires for the use in my garden. My tractor has about all of the options available for that model.
Pros: Good size for having a garden and small wooded acreage. No problems with the 3 cyl. engine.
Cons: A few minor hyd. leaks. Need a good parts list book to order parts.
3.00 star(s)
Brock kimmet
JM-224 Jinma
2005 Jinma 224
Model Year: 2005
My Jinma 224 for the most part has been an alright tractor-at best. I primarily use it to mow by pulling a 6' Land Pride finish mower and install a few fence posts. My tractor has required a lot of maintenance i.e. hydraulic issues, electrical problems etc. The engine however has given me no problems what so ever. I change oil and fluids as scheduled. My current problem is adjusting the 2-stage clutch. with the amount of hours on the tractor I'm probably going to need to put a new clutch in it.
Pros: Strong reliable motor.
Cons: Hydraulic problems (fluid bubbling out of breather cap), electrical problems at the fuse block!
4.00 star(s)
wsmetz10
JM-224 Jinma
Jinma 224
Model Year: 2001
Excellent value for cost.
Pros: Less expensive then name brand.
Cons: Less refined body finish.
4.00 star(s)
OKnewguy
JM-224 Jinma
Jinma 224, FEL Koyker 160
Model Year: 2004
I picked up the 224 with FEL and Box Blade for 8K, It was the previous years model but still new. It has proven to be a very good value. Are there nicer tractors, you bet. For this price range it is hard to bet.
Pros: Cheap, Value, Simple, Basic
Cons: Very little bells and whistles, you might need to tinker.
[ad placeholder]
Jinma JM-224 Owner Pages
View owner pages to see photos, customization and comments about member-owner Jinma JM-224s
Jinma JM-224 Community Rankings
#194 user rating of 731 Under 25 HP Tractors items
#44 Viewed of 731 Under 25 HP Tractors items
#30 discussed of 731 Under 25 HP Tractors items
#1364 user rating of 19625 items overall
#228 Viewed of 19625 items overall
#185 discussed of 19625 items overall
Highest Rated in This Category
    No results found.
