Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #1
The Suburban Farmer
Northern Virginia
Deere 2320
I inherited some old Oneida Victor animal traps from my father (circa pre-1920 or so) and they were in pretty rough shape after sitting in a cardboard box in the garage for 30 years. I have several, and they aren't ever going to be used for trapping again, but they do have a LOT of sentimental value, because he paid for his school supplies as a kid by trapping and selling fur -- that was the only way he could afford to finish high school. He went on to become an electrical engineer after serving in the Army (thank goodness for Army-paid training and GI-Bill educational funding!) He sent all of his own kids to private colleges, so I look at these traps as being the pivotal driver of his success in his later life -- and ultimately the driver of why I'm comfortably middle-class and well educated today, and able to give my kids a good life.
I wanted to bring these back to life and mount them for display -- I think it's a great reminder to my own kids that life wasn't always so easy as it is today, and we take things like money and comfort for granted. They ADORED their grandpa, and they couldn't hardly believe his stories about how he had to get up at 4AM every day during the school year to check his traps just so he could afford shoes and books and pencils, just so that he could finish high school. They only knew their successful "upper middle class" grandpa that had a nice house and bought really cool Christmas gifts and owned a REALLY cool old Ford tractor that they enjoyed riding with grandpa at the wheel -- not the poor farm boy that worked his fingers to the bone just so he could get off the farm, avoid the coal mines, and make a better life for himself.
Anyway, I didn't want to grind them or wire brush them, so I rigged up an electrolysis bath:
Supplies:
  • Water
  • 1 cup of Arm & Hammer Washing Soda (NOT baking soda)
  • An automotive battery trickle charger or bench power that puts out low-amperage DC current
  • 4 old pieces of rebar (steel, NOT stainless steel)
Steps:
  • Mix up the solution of water and around 1 cup of washing soda per 5 gallons of water to create an electrolyte solution that will conduct electricity in a PLASTIC container
  • Connect the rebar with wire so that they are all connected, but not fully completing a circuit (leave 2 of them unconnected) and leave enough wire to attach a lead from the battery charger
  • Sand enough rust off your part to get a good metal-to-metal contact and then wrap a separate wire around the item to be cleaned
  • Connect the NEGATIVE to the ITEM TO BE CLEANED (remember, "black to rust")
  • Connect the POSITIVE to the wire connecting the sacrificial annodes (the rebar)
  • Turn on the charger (ideally set to <2 Amps to minimize any pitting)
  • Watch for micro-bubbles to start appearing... bubbles means "it's working"
I used a 5 gallon bucket, and the setup looked like the pics below, but you can make this as large or as small as you want, depending on the size of the part.
Here is a before and after pic after about 6 hours:
Here's a final pic after about 24 hours in the machine, and then a couple of rounds through my Harbor Freight ultrasonic cleaner and a good rubdown with a scotch-brite pad. The black residue that remains can be sanded or wire brushed off, but I like the look this way -- looks more "antique" than "brand new" which is what I was going for. Cover with some oil to prevent surface rust, and voila -- restored antique traps with (almost) no elbow grease.
Now, I just have to make a nice display board so I can mount these and hang them on my office wall.
NOTES:
  1. Don't use stainless steel EVER. If you do, it will release the chromium atoms and create the Erin Brokovich chromium 6 toxin (hexavalent chromium.) Very nasty stuff.
  2. If a magnet will stick to your rusty piece and your annodes, then you're good to go.
  3. Don't mix up your positive and negatives -- get them wrong, and you will clean the rebar and all the rust will be attracted to your antique part.
  4. So long as you follow rule #1, you can dump the residual water down the drain -- it's 100% non-toxic and safe.
  5. This only works in "line of sight" -- that is, if there isn't a straight path fromthe part to one of the annodes, it won't work -- add more annodes if you have a complex part, but I found 4 to be enough in a 5 gallon paint bucket
  6. You can leave the part in the solution and run it for days if necessary. The reaction will stop when there is no more rust -- no need to monitor it or risk damaging the part by leaving it in too long. It may take several days for a badly damaged, or a highly intricate part with a lot of nooks-and-crannies
  7. It will gather some surface rust almost immediately when you rinse it off, so make sure you either paint it or oil it ASAP after you've rinsed and dried the part
  8. You CAN use more power (amps) but it doesn't really help the speed much and you risk pitting the material due to the reaction being too intense. While this turns rust back into metal, there are "micro-explosions" of hydrogen gas happening, and these can pit soft metal if the amperage is too high.
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #2
Awesome! I bought some washing soda a few years back with the intention of doing this on some small parts I wanted to restore. Life got in the way and I never got to it, but enjoyed your writeup, especially the reason. thanks for sharing.
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #3
Excellent write up and great project!
I've been using electrolysis for years rebuilding old tractors and farm equipment. It also works really well for painted sheet metal if it's scratched and rust bubbles are breaking through the paint. If it has a bare spot to start from it'll work it's way right under the paint and lift rust, paint and all.
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #4
Excellent results. And excellent write up too. :thumbsup:
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #5
I used the same method on an old heating vent from our bathroom. It was in pretty bad shape, being in a damp, warm environment. People would kick it and knock paint off of it, exposing metal to rust. A couple days in the vat and it was clean as a whistle. Good primer and paint and better than new.
Its a fun way to get things cleaned up.
I'd caution more on the Hydrogen issue, though. All the little bubbles you see coming to the surface are hydrogen gas. Don't do this indoors and don't do it near an open flame. Also, turn off the battery charger before connecting or disconnecting the electrodes/work-piece to avoid sparks. I did a couple science experiments in grade school 45 years ago with this and let's just say I was surprised how powerful of a boom you can make with a small balloon full of hydrogen and a fuse! :eek:
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #6
The science teacher did the water "cracking" electrolysis thing in class and had Oxygen coming off of one electrode and Hydrogen off of the other. We did several experiments including making an extinguished match burst back into flame when stuck into the oxygen tube, and of course the hydrogen "boom" you mentioned. Pretty exciting stuff for a kid.
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #7
Very cool! Thanks for the writeup.
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #8
Very interesting. That's one thing I've never tried, and wouldn't have thought of. I'd have gone to the sandblasting cabinet, but your method might very well be better.
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #9
Works for rusty old motorcycle gas tanks as well
Mark
   / Electrolysis Tank For Restoring Some VERY Sentimental Antique Traps #10
I did the inside of a 1000 gal hydroseeder tank once using this method, except I used my dc welder instead of a battery charger. I attached my ground lead to the outside of the tank and suspended all kinds of metal, rebar, angle iron, etc, inside the tank. Turned the welder down to 20 amps, its lowest setting and turned on the welder. Cant remember how long it took, but not over a couple of days. Tank turned all black inside and the process even removed the coal tar epoxy that was used to prevent the tank from rusting in the first place. I used the POR15 Metal Ready (phosporic acid) to etch the metal and a couple of coats of POR15 paint to finish the inside and it looked like new. That POR15 paint is some kind of epoxy and when dries you cant sand it off. Cant get it off you skin either, or out of your hair. If you have ever tried to paint the inside of a tank, you know how you get paint in your hair. LOL
48" QUICK ATTACH PALLET FORKS (A52706)
48" QUICK ATTACH...
2010 BIG TEX 16 T/A TRASH TRAILER (A55745)
2010 BIG TEX 16...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
2001 Nissan Pathfinder SE SUV (A55853)
2001 Nissan...
Freightliner Tender Truck - Adams Tender (A55302)
Freightliner...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
