Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,321
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
I got a new shop. It's a 14x24foot bay of a 3-car garage. It's covered with pegboard. I'm not too thrilled about that. maybe i can learn to live with it. or maybe I'll cover it over. I blew in AttiCat insulation behind the pegboard. AttiCat doesn't seem to come out of the holes, but if it does I'll cover it over.
There will be other projects but this thread is the workbench. It uses removable heavy plastic tubs for drawers.
The idea being that I can pull a drawer out and head out for a job.
For example:
A drawer full of plumbing stuff, torch, solder, paste, elbows etc.
A drawer of all my drywall tools and supplies, tape, knife etc.
A drawer with electronics stuff, soldergun, solder, wire, crimp connectors, crimp tools
A drawer with house electrical stuff, j-boxes, clamps, wire nuts, short pieces of romex etc
A drawer under the vise with the cut-off metal ends, shapes, small sizes that I want to keep
A drawer of miscellaneous bolts, nuts, washers
A drawer of wood screws, wood fasteners
These tubs "cross-stack" so I can stack 3 or 4 of them in the back of my pickup, run a ratchetstrap over the top tub and cinch the stack down.
First of all, I hope this plan works, and if it does, hope y'all like it!
Here's what it started with. Tore this old workbench out. And that hairdresser sink. It wasn't hooked up. This house was a rental for 10 years who knows what went on in there. The drawers ALL worked, it coulda been painted and look nice, but I couldn't see moving my shop into those drawers. I had a new plan.
Built a steel structure from 2x2x.063 steel square tubing. Screwed it to the studs. I'm abandoning those outlets cuz they're centered at 40 inches, which is my benchtop height. I'll cover them over with a 'backsplash'.
Angle-iron drawer glides. Used a story-pole method to set all the drawer glides.
Closeup of the story pole.
Set some plastic tubs on the drawer glides. The tubs are 24 x 17 x 8" deep.
Can pull out the lower tubs, and the floor is clear, a broom can sweep under, to find lost sockets, nuts, and needle bearings etc.
Got one bay done. Each bay is 60 inches.
I will use smaller tubs for the next two bays, so each bay has 16 drawers.
For example:
RenderedContent-AAC90FCE-ACD8-446B-AD46-28DA53EF63EA.JPG117.7 KB · Views: 2,250 -
