Skidding winch
   / Skidding winch
I agree with once owning one you couldnt imagine living with out it but I just wish there was a more affordable way to do this for the home owner just looking to cut 6-10 cords a year for themselves. But I guess convenience comes at a cost.
Its too bad the belt drive one wouldnt work for light logging. It would be cheap and easy to build and I have most of the stuff laying around with exception to the belts and pulleys. Biggest trees I would be harvesting around here would be in the 14 range but most would be 10
   / Skidding winch #42
Here's a new winch for $2695, if you're within traveling range of Berlin NH. Norse 35 3 Point Hitch - 3-6 HP
I'm not sure what the shipping charges are if you live farther away. (Note that TBN drops the zero when posting links, it actually says 30-60 HP)
They've really gone up since I bought my first one. Back in 2002 I could have bought the smallest Farmi for $1200.
   / Skidding winch
Thats actually not a bad price but I live in the cold frozen north of the Canadian Precambrian shield, hence the small diameter trees. Minus 35c here today. just another day in paradise.
Thats why in a lot of my posts you will notice I have a tendency to want to build tractor attachments rather than buy. Not a lot of tractor supply places around here. Closest one is 6 hour drive south. ****, I have only two roads out of town. One road has one town between us and civilization 350km away and the other is a 325km drive just to hit the next town and its smaller than my town. The joys of remote living but I wouldnt have it any other way.
   / Skidding winch #44
Here is mine I built last winter. It works great, very similar to commercial made units, I have refined the engagement mechanism since the "first pull" Homemade logging winch first pull - YouTube
I have 200 ft of cable, a 6-1 gear reduction via chain and sprockets, a clutch between the large sprocket and drum, I estimate it at about 80ft/min, it could be faster but it works as is. I started with a budget of $500. I ended up at a little over $700, still not bad for what it is. I pulled out about 8 cords this spring with it and it worked great once I got the bugs worked out. My build of it can be found here https://www.tractorbynet.com/forums/build-yourself/386238-diy-logging-winch-build.html?highlight=
Any questions feel free to ask and good luck, it was a fun learning experience.
That looks like it's working well for you. For the sound of it, you were running at rather low engine RPM in that video, so you could get more speed if you wanted on an easy pull?
Any idea how much pull you can get with that?
   / Skidding winch #45
I searched for years looking for a decent used one, since I just couldn't justify the price of new for my own use. When I went in on a partnership with some other families in my area on some more forest land, I finally bought a new one. I figured we'd get enough use out of it as a group. It's worked out well. I generally barter winch services for other help (I HATE cleaning up and moving brush when we are done. Others are gratefull enough for the winching help that I seldom have to clean up by own slash.)
Is there anyone around you'd consider going in as partners with on a winch?
Its too bad the belt drive one wouldn't work for light logging. It would be cheap and easy to build and I have most of the stuff laying around with exception to the belts and pulleys. Biggest trees I would be harvesting around here would be in the 14 range but most would be 10
I don't know... that belt drive seems to work well enough for the guy who made that winch. I doubt it's the equal of a commercially made logging winch, but it's an interesting idea. If I had most of the parts other than the belts and pulleys, and didn't mind putting some time into it, I just might start keeping my eye out for some cheap used pulleys and let that decide whether I tried to make one or not. If you have the time to put into it, it's hard to beat almost free.
   / Skidding winch
I totally agree that the belt drive one isnt even close to being in the same league as the commercial ones but I was impressed to see that it worked pretty well for him. I work at a zinc and copper mine and they have lots of old parts from from years of upgrading the milling equipment. I will scrounge around and see if I can find some old parts they are willing to give away. If I can, I will give it a go. Even if it doesnt work out it will be a fun project to try.
Im sure you would find out quite quickly how much that winch would pull because the deciding factor woul probably be the slippage of the belt system. Im thinking it would be hard to overload that winch.
   / Skidding winch #47
The winch in the video was built pretty light duty. Understandable since it’s on a tiny tractor. I think you could upscale the concept to work on a stronger winch. You might need a power assisted tensioner but the concept is sound. They transmit a lot more power than you’ll get out of a compact or light utility tractor with belts. You could use a gearbox to reduce the drum speed and drive the gear box with belts at a 1-1 ratio to significantly reduced the toque on the belts.
   / Skidding winch #48
Yes I was only running at just above an idle so yes, I could get more speed if I throttled her up. I'm still learning it's performance procedure...lol
The cable I have is only rated at 4400# so I'm not sure on actual pull. I know I pulled some pretty heavy logs if you watch this Take of the day, firewooding. - YouTube it will give you an idea of the size of some of the trees I hauled with it.
If I owned a woodlot and didn't rely on scrounging places to get firewood I would invest in synthetic rope for the winch, I have it on my Jeep and love it.
One thing I would like to change on mine is to make the spool a little shorter, the way the cable is wound naturally it only uses part of it anyway so I may experiment this winter with welding in some sides to the spool to limit it.
   / Skidding winch
So you are saying run the belts from a shaft driven from the pto to the input shaft of a gear box and then have the winch on the output shaft of the gear box.
   / Skidding winch #50
Something like that. It would reduce the torque on the belts.
6ft Field King 3 Point Hitch Tiller (A51573)
6ft Field King 3...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
