Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,802
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I wanted to put a plow on the M5640. I found a guy who wanted to restore a '91 F150 and would give the plow to someone who would take it off the truck. So I did. The plan was to sell the pump, valve/control, head gear, and truck frame parts and start out ahead but that hasn't happened.
I really liked the concept shown by TractorNH in this thread: https://www.tractorbynet.com/forums/build-yourself/401291-snow-plow-build-finished-underslung.html and decided to build with that idea. Here is my version
For my use I saw these advantages: 1) Plowing - The blade rides along and follows the road surface under it's own weight just as it does on a p/u. I have a long irregular gravel road. A plow with a solid SSQA attachment would be a problem for me. In float the weight of the FEL is on the plow making it very heavy which is not good on a unfrozen gravel road. If you take the FEL out of float you have to constantly control the blade height. No problem on a flat drive way but very difficult on a long rough road.
2) Better Steering- Because the blade is set back and not way out front less side leverage is applied to the tractor when plowing with an angled blade which is the normal mode for a long road. And, the weight of the loader arms and heavy SSQA frame hang out front and put extra weight on the front tires for better steering traction.
This is how the build progressed. First I built a new push beam. The old one had seen better days.
Then the basic frame. I plan on serious plowing with a heavy tractor that is not easy to stop so I think that I made it strong. But I really have no clue about what is strong enough. The square tubing is 2-1/2" X 1/4". The angle is 2" X 1/4". Same width as the push beam and as deep as I could and still allow the plow to angle fully.
Two posts for attachment to the SSQA plate and line up with the loader arms and tractor SSQA push pads.
Welded on the new push beam.
And added some corner brace plates plus a length of 3" X 3" angle between the two posts for a weld point across the bottom of the SSQA plate
Set the SSQA plate level to the push beam
Added some angle braces - frame to SSQA plate
A stiffener across the plate to catch the angle braces
Made an easily adjustable attachment point for the lift chain and storage for the loose slack chain.
Finally some primer
The hydraulics include a pair of flow control valves and a cross over relief valve
Mounted on the tractor
And it can push snow. Harder than my one ton actually.
I know this is overly complicated compared with most designs but it just happens to be the way I did it or how it turned out. Just take it for what it is.
gg
Finally some primer
gg
