Need pole / post advice: Extending a shed roof
   / Need pole / post advice: Extending a shed roof #1
rbstern
GA
LS MT225E, Yanmar 2210
I set up my sawmill near my shed, with a couple of intents in mind: 1) The shed is going to be used for drying wood, and 2) to extend the shed roof to a pole / roof structure (similar to a porch roof) that would offer shelter to the last section of the sawmill track, so the sawmill head would be out of the weather without needing to put a cover on it.
A couple of weeks ago, I cut a couple of 5x5 posts from a pine log, intended to be the poles for the roof extension. I've been pondering how to set them to keep them from rotting. My instinct is to auger holes, fill with concrete, and anchor the posts on top of the concrete, just above the ground. The disappointing part of that thinking is that typical galvanized anchors for posts cost as much or more than PT posts. Seems counterproductive to have a sawmill and then spend more to protect the sawmill wood from rotting than the equivalent PT wood from the orange big box store costs.
Another possibility would be adding a piece of vertically set rebar to the concrete, and drill a hole in the post end, inserting the rebar into the post end hole, to act as a lateral brace. And maybe a simple, galvanized L bracket to resist uplift.
Pic of sawmill/shed end follows. I happen to have eight bundles of that exact roof shingle left over from our house build, so my plan is to blend the roof of the extension to the shed.
Input greatly appreciated.
   / Need pole / post advice: Extending a shed roof #2
They're not cheap but very nice and I'm sure you've seen them before but I really like these brackets for anchoring to concrete. They've got wet set ones as well.
Another option I've done in the past is cut pieces of angle iron the wide of you post then anchor to the concrete followed by lagging or bolting through the post to the other angle that's you've anchored to the concrete.
   / Need pole / post advice: Extending a shed roof #3
Find some locust or white oak logs to cut the posts out of instead and set those on the concrete. Far more rot resistant than pine.
   / Need pole / post advice: Extending a shed roof #4
My lean to roof is posts set on concrete pads under the ground to take the pressure - then a foot above that a kind o concrete collar with sixteen penny nails driven into the wood to prevent movement. I did use PT 6 X 6 posts. You could consider a concrete pad on the ground with a steel separator to keep the post from direct contact with the concrete.
   / Need pole / post advice: Extending a shed roof #5
Don't know if it's still possible with all the greenie-weenie stuff, but my dad had some poles treated with penta for a boatshed. They dipped the last four feet in the solution, enough to leave a bit of the treated wood above the ground line.
Utility poles are still treated, someone is doing it, just have to find the right people.
   / Need pole / post advice: Extending a shed roof #6
Where abouts in Georgia are you? Don't y'all have eastern red cedar trees ? That's what I use in central SC for building posts. I mainly use 6x6 posts around the farm whenever I build anything.
   / Need pole / post advice: Extending a shed roof #7
Yup!
Pine logs will rot within 15 years, no matter how you set them.
   / Need pole / post advice: Extending a shed roof #8
We have had a hitching post in the yard, from the previous owner,, since we bought the house in 1982.
He made it out of taken down telephone poles,, so, I guess the total age of the creosoted poles to be 80 years.
The creosoted poles were 100% rotted, even the horizontal one that was not touching the ground!! :eek:
I went to the local Southern States Farm Supply, they had 6-7 inch top posts, ten feet long, for $16.95 each, I bought two.
I cut one in half, and rebuilt the hitching post.:D
The posts are 0.40% CCA treated,,I think that is the best you can generally get,, now.
When I built my first shed, I used 0.60% CCA treated posts. They were put 48+ inches in the ground.
I took out one of those 0.60% treated posts after 25 years,, it literally looked like it had never been in the ground.
I will bet the 0.40% CCA treated posts I installed last week will be rot free at the turn of the next century,,
North GA, right across the border from Anderson, SC. Yep, we have cedars, although I can't be sure they are Eastern Red Cedar. Far less numerous than pines, so some difficulty finding and harvesting, but they are there. We also have a fair amount of white oak.
   / Need pole / post advice: Extending a shed roof #10
What I did was use pressure-treated 6 x 6 posts, set on concrete circular discs in the bottom of the holes.
I did a similar thing when I built my shed about 25 years ago (maybe, forget exactly when). No issues at all. Looks like the posts will last forever.
Put this 28x16 roof on the side of the shed last fall. Same motivation as yours. Plan on putting my small sawmill under roof, at least the power part. Did more excavation of the area beyond the roof after photo was taken.
I plumbed the posts and added a bag of concrete mix plus water to each hole to hold the post bases in position when back filling the holes.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A49461)
2015 Peterbilt 579...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
