Widen rear tread width
   / Widen rear tread width #1
Jesser02Ex
Branson 5220R
I have read several posts here about widening the rear tires on my 5220R. My tractor has a dish/rim combo that allows the most flexibility for width. Since I have not done this before, I wanted to seek validation before I tackle this task. Once widened, I will fill the tires with a 50% window washer mix.
Here is my manual page, it says nothing about the dish/rim combos.
My inner dish is turned to give the most spacing:
I believe all I need to do is unbolt the rim from the dish and move it to the outside inner dish and torque the bolts per the manual.
Am I missing anything? I have everything to chock the front wheels so it will not roll as I lift the rear of the tractor.
   / Widen rear tread width #2
You could check with the dealer that the setup you plan to use is approved. It should be in the manual.
You'll need a way to move the rim and tire around without it falling down (it'll be really heavy) and a way to line it up to get the bolts in. Some people here have used a greased sheet of plywood. If I was doing it I'd chain it to the ROPS or something else so it wouldn't fall over.
   / Widen rear tread width #3
You should look at the mounting bracket on the wheel, if it's offset closer to one side or the other, you can gain/loose width if you swap tires/wheels side to side as well.
   / Widen rear tread width #4
Yep. Looks offset.
Currently it's offset in plus mounted inside the center. A lot of width to be gained.
Eric, thanks for the idea of using the ROPS to keep the wheel upright.
Richard, yes the dish is pushing outside, the well is inset on the dish. I’ll mice the wheel to be outset on the outset dish. I believe this will give me maximum offset with factory adjustments.
Thanks all
   / Widen rear tread width #6
View attachment 586200 OK. This is from my Kubota M6040 OP Manual. The first bigger sketch shows one position with the hub dished inwards. If your welded attachment tabs, on the outer rim, are offset, there will be three more positions, with the hub dished inwards.
The next four sketches show the four positions with the hub dished outwards.
Each of the eight positions is only an overall change - in total width - of a few inches. However, the idea being - ideal width when doing row crop farming.
The reason Kubota does not recommend the added three positions when the hub is dished in - possibility of the outer tire making contact with components of the tractor.
So, if the attachment tabs on your rims are offset - you too will have eight width positions. No matter what you do - - be certain that there will be adequate clearance if you do make width adjustment.
   / Widen rear tread width #7
This is from the 15 series. It's odd that they didn't put that info on the 20 series for some reason.
The dimensions won't be the same as this is a smaller size tractor.
It is odd that it wasn't included in the 20 series manual. You have posted this image before and I referenced it before checking my manual in hopes I would have the same graphic. I also looked at a downloaded manual for the 20 series, it also excluded this graphic.
My rear wheels are currently set to "E", but I will move them to "F" for maximum stability. Thanks for re-posting this graphic.
   / Widen rear tread width #9
Not exactly maximum. The diagram shows the tabs in the center of the rim width. As overszd noted, the tab on the outer rim is offset (not in center of rim's width). - Or looks to be anyways. If you move that tire to opposite side (so that tread direction remains correct), then the tire spacing will be maximum width (stability).
   / Widen rear tread width #10
To be honest, the diagram they provided can be a bit confusion as they didn't draw the axle so we could have a reference on what is the inside and the outside of the wheel.
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A55787)
2017 JLG Skytrak...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
Cat TH407C Telehandler (A53472)
Cat TH407C...
1827 (A51248)
1827 (A51248)
